CBX front sprocket for rear wheel upgrade
Started by SILVERGOAT, January 03, 2010, 04:55:38 PM
Silvergoat,
Make sure you let us know what you came up with, and how the CBX front sprocket worked out. I was considering doing this myself, and wondered how it would line up with the rear sprocket without any machining to the sprocket carrier.
:unknown:
I haven't seen it mentioned in this thread yet -- you can also "flip" the rear sprocket to help with the alignment.  All the steel rear sprockets I've seen for these rims are dished and will move the chain toward the center of the motorcycle slightly if mounted the other way.  I don't remember how much is typical, and I've seen different sprockets have different amounts of "dish" so the offset could be slightly different between different brands.
Good luck!  Please post up your results when you're done.
Why couldn't a regular countershaft sprocket be shimmed out the correct amount?
DLR
Quote from: SlowOldGuy on January 14, 2010, 10:10:36 PM
DLR
I've always wondered that too!   :pardon:
the fan
DLR
Havn't looked at a FJ c/s in a while, but if it is similar to my YZF the splines are too short, The safety lock washer engages the splines on the Countershaft to hold the nut in place. shimming the sprocket out would require removing material from the face of the sprocket to accommodate the lock washer.
Brook
..... I have a 86, with a YZF1000 swingarm. and a 180 Avon on the back.....[ very happy with the Avon]
I could not find the front sprocket for the Honda, at that time [ about two years ago]
But, I did find a machine shop, in Clearwater Fl.  that makes front sprocket. ....
This shop, also, runs drag bikes, So, You know that they can handle the horse power.
and yes, I had to make room in the cover for the offset 18 tooth.
                                 Jeff
