A few questions on maintenance for a "new" 93 FJ1200
Started by wirehairs, March 01, 2015, 11:15:43 AM
Quote from: Capn Ron on March 04, 2015, 11:55:12 PM
Excellent point Pat!
H is rated for 130MPH...but I was running the Pirelli Sport Demon in the front and an Avon Roadrider in the rear on that trip.  They're both V rated for 149MPH.
...But we never cracked the 65 MPH speed limit.   :biggrin:
I thought that speed rating was: at that speed, sustained for a prolonged (30 mins?) period of time.  -No?  I also thought I read where most/ all H rated tires will do much more than advertised, but you just would not want to bet your life on it -which is good council, of course.
magge52
Quote from: Dan Filetti on March 05, 2015, 02:23:08 PM
My mechanic told me the same thing about the H rating when I was looking to reshod the FJ last season. I think that's typical for tire ratings. I bought Pirelli Sport Demons and for street use they have been great. Pirelli calls them X-ply, the front is H rated and the rear is V rated.
92 FJ1200/abs
97 Duc 900ss/sp
75 Norton
moparman70
WELL --- I am for stepping down to the 110/70-17 radial front  --- its not that much smaller than the 120 and is made for a 3 inch rim ---- spec last time I checked 2.75-3 inch ----  and the 120 was 3 - 3.5 ---- so why not go to the 110 and go with the upper end of the spec ( wider rim size for that size tire) .
AVON STORM 3-D XM --- are available for the front in both 120 and 110 sizes so if you want you can go the other way too.  And they have a rear 150 -- if still pushing the stock rear.   V- rated as during my commute I do frequent the higher speeds and need that for safety
I like mine -- so far but I haven't given them the PaLomar Test yet.
sc2
craigo
Quote from: moparman70 on March 06, 2015, 07:23:41 PM
sc2
After the snow melts and the roads are clear of sand, I'll join you.  :i_am_so_happy:
CraigO
CraigO
90FJ1200
Quote from: craigo on March 06, 2015, 09:09:56 PM
CraigO
Count me in...
stua1959
I went with a 110 radial front and feel that it is much better suited to the 3" rim. After the first few rides I had very narrow chicken strips whereas the 120 still had plenty of untouched side tread. This tells me that the area of the tyre that was designed for cornering is now being properly used
Quote from: stua1959 on March 07, 2015, 04:14:06 AM
Yeah, I think you're on the money Stu, 110's the way to go with a 3" wheel.
yamaha fj rider
Quote from: ribbert on March 07, 2015, 05:54:29 AM
+1 I remember reading somewhere that the 120 that came on these bikes was only 112 mm.
Kurt
93 FJ1200
FJ 09
YZ250X I still love 2 strokes
Tenere 700
FJR1300ES
Quote from: yamaha fj rider on March 07, 2015, 08:25:59 PM
Kurt
The 120 Conti's I use are only 110mm.
Just checked my Sport Demons and they're both V speed rated.  The front load/speed rating is (58V).
According to Wikipedia, "It indicates the maximum speed at which the tire can carry a load corresponding to its Load Index."
I take that to mean that the tire is rated up to 149MPH while carrying its 520 pound maximum.  I'm having a hard time finding any verbiage on "time at speed".  Our front tires don't see nearly that much weight so I'm surmising some margin of safety there as well.
Quote from: Capn Ron on March 08, 2015, 03:09:27 AM
Did you find any info on their "Off-Road" capabilities?  :sarcastic:
wirehairs
In the end, I decided to go with the 880's with the bias ply.  In case anybody else is going to buy some, the promo code PB-S1METZ right now at Motorcycle Superstore nets you another 5% off.
Cheers!
Quote from: Capn Ron on March 04, 2015, 03:34:05 PM
Here's the Metzeler ME880 front available from Motorcycle Superstore:
http://www.motorcycle-superstore.com/6126/i/metzeler-me-880-marathon-touring-front-tire
Says there are 6 left in stock. (120/70VB-17)
And the rear:
http://www.motorcycle-superstore.com/6127/i/metzeler-me-880-marathon-touring-rear-tire
Says they have more than 10 available.  (150/80HB-16)
Revzilla also has them in stock, but they're a bit more expensive there.
Before I left on my trip...and after a ton of research, this is the tire I wanted.  I called six local dealers and they all told me that Metzeler no longer makes the ME880 in my sizes.  They were wrong or lazy or just wanted to sell me what they had on hand...or all three.   :dash2:  In a seeming bind, I had them mount up Pirelli Sport Demons...as much as I liked them, they were worn out in TWELVE days of touring.   :shok:
