92fuel tank on an '86
Started by fjfool, January 19, 2015, 09:43:25 PM
fjfool
i hope this is actually not a modification
i have a 92 tank that is cleaner than the one on my '86, i believe it is more worth touching up and painting
are the tanks physically the same?
can i just change out the fuelcocks?
thanks
The '92 tank will fit on your '86. The petcocks are different and will not interchange between tanks. The '86 petcock is vacuum actuated and gravity fed to your carbs. The '92 tank's petcock is free flowing and goes to a fuel pump that feeds the carbs.
There are two options for swapping the tanks.
1st option, Install a small ball valve inline between the petcock and your carbs. You will HAVE to shut the valve every time you turn the bike off.
2nd option, install a '89 or later fuel pump, fuel filter and retrofit your carbs.
There may be more options and configurations. These are the issues that I know of.
fjfool
"The petcocks are different and will not interchange between tanks"
bummer, just cant be that easy can it
i suppose the Pingal petcock would work
has anyone used one of these? how hard is it to reach?
thanks for the help, Fred
Quote from: fjfool on January 20, 2015, 07:43:29 AM
Just put a 12v shut off valve in the fuel line somewhere.
Ignition on, fuel flows, ignition off, it stops.
Manually turning the fuel on and off is a bit primitive.
JMR
 I use a Pingle adaptor plate with a 90 degree fitting and their inline vacuum shut off. http://www.pingelonline.com/pc_product_detail.asp?key=3CCC32F0434D41F0B6C89EC32D85EB11  Has worked great over the past 3 years
fjfool
sorry, having some tech difficulties
FJ1100mjk
Quote from: ribbert on January 20, 2015, 07:56:27 AM
I have seen this solution proposed in the past, but have yet to see a solenoid shut-off that could be packaged within the the small confines on an FJ. If you have one in use in a FJ application, I (and others) for one, would like some information and pics of its install.
The only other viable fuel shut-off that I have seen that shows promise is this, but it is still pricey:
Iron Balls #00002175
www.ironballs.com
JMR
Quote from: FJ1100mjk on January 20, 2015, 08:39:16 AM
Looks familiar. :biggrin:
I used a pingle copy on my 86 (now has a small leak and is not rebuild able shoulda got the pingle). To access the lever to shut it off. I just bent over the black screen on the top slot of the side panel. Its right there.
I've now collected all the components to convert the 86 to fuel pump. Mostly so I can run a filter.
FJ1100mjk
www.ironballs.com
FeralRdr
Not the cheapest solution and you would still have to use an adapter plate, but it may be possible: http://www.pingelonline.com/pc_product_detail.asp?key=7309EE24013946E4AA8A0135B6A16DCC
FJ1100mjk
Quote from: FeralRdr on January 20, 2015, 11:18:13 AM
$348.00! Cough/gag.
Bet you're glad you have that Ninja 1000 now, huh?  :smile:
www.ironballs.com
Wrong application:
Electric-Flo™
Tired of trying to find the perfect spot to hide the ignition switch on that custom bike? Well, that headache is gone with the Electro-Flo™ Fuel Valve because when you turn your gas one, you turn the bike on also, which is a feature like no other valve in the industry. Pingel Enterprise, Inc. and custom builder Darrian Tefft teamed up to develop the Electro-Flo™ Fuel Valve. The result is no more forgetting to trun the fuel valve on, starting the bike, and taking off only to have the bike kill because it has run out of fuel. The Electro-Flo™ Fuel Valve utilizes the Guzzlers inpressive 211 oz. per minute flow rate along with outstanding race tested durability. The Electro-Flo™ is manufactured from billet aluminum the polished to a show-quality finish.
copper
I bought a petcock replacement from RPM its a manual petcock but it bolted right in and I believe it was a Pingel.
http://www.rpmracingca.com/proddetail.asp?prod=M%2FC%3AFJPetcock
FeralRdr
Quote from: Pat Conlon on January 20, 2015, 11:59:33 AM
Wrong application:
Electric-Flo™
Woops!  :blush:
Yep! Definitely misread the description, and didn't look close enough to see the switch on it. Sorry if I got your hopes up.  :pardon:
