Cam chain tensioner
Started by groome, January 09, 2015, 06:15:27 PM
groome
Hi all now the bike is off the road for winter I have dived into finding an oil leak that's been bugging me. I have found its coming from the cam chain tensioner gasket. My question is it possible to change the gasket just removing the tensioner without risking mucking up the timing?
Simon
89  fj12 banshee
Normal = BORING
oldktmdude
   Shouldn't be a problem. Do not turn the engine over until the tensioner has been re-installed!  Pete.
1985 FJ1100 x2 (1 sold)
2009 TDM 900
1979 Kawasaki Z650 (sold)
2001 KTM 520 exc (sold)
2004 GasGas Ec300
1981 Honda CB 900 F (sold)
Beat me to it  Pat  :good2:
I might add you will probably need to pull your air box and carbs. To do the job. At least with mine it took some tension on the socket to get it back together.  Make sure it is installed correctly. There is an up or down side :).  Details....  :good2:
FJ1100mjk
Quote from: movenon on January 09, 2015, 06:44:48 PM
Yea, like making note of how its installed (oriented), before you remove it.
Iron Balls #00002175
www.ironballs.com
On my post I said "tension" it should read pressure... You have to push against and stiff spring.
groome
thank for that guys.i might get stuck into it after work  :good2: :good2: :good2:
89  fj12 banshee
Normal = BORING
