Misc. Things
Started by Bluezero, January 09, 2015, 02:33:57 PM
Bluezero
Hey y'all, got an 89 Fj1200 with about 80k miles on it and the other day I noticed that I could smell gas in the oil. I think I've narrowed it down to the choke not functioning properly as cylinder four will not fire when it is on. The only thing I can guess is that maybe the gas is washing down the cylinder walls when the choke is left on too long. I remedied it by not using the choke for too long and using a bit of throttle to keep it on till it's warm. This has kept anymore gas from getting into the crankcase but does anybody have any ideas what could be causing this to happen when the choke is on?
Also, the cam chain is fairly loud which I hear is normal but I called a shop and asked if they could swap out the tensioner and the guy informed me that the whole top end of the engine probably needed to be refreshed with new gaskets, rings, chains, and valves which he told me he could do for around 800-1000$. I've heard these bikes are fairly bulletproof so is this something I should be considering at such "low" miles? The mechanic also told me he hasn't worked on one for 20 years so he may not be familiar with their longevity. Sorry for the wall of text and thanks!
Remove and clean your carbs , check jets and float heights , emulsion tubes etc. Be sure to examine the choke linkage for wear and proper travel.
Gas in the oil is very bad for your engine. Set idle to 1100rpm and see if the rattle went away.
Bluezero
I will get on checking those things. As for the idle it's currently set to 1100 rpm and I can hear it throughout the rpm range and speeds up with higher rpms.
roverfj1200
Quote from: Bluezero on January 09, 2015, 03:49:02 PM
Would most likely be the starter chain or alternator chain. I think you can get a rattle from the starter clutch to (someone will chime in)
FJ carbs are known to leak from time to time and I have found if left on the side stand overnight fuel can run into the lower cylinder. Good carb clean and adjust will minimise this.
1988 FJ1200
Richard.
Bluezero
Quote from: roverfj1200 on January 09, 2015, 04:14:58 PM
Okey doke thanks, I hear the sound coming from the front of the engine which is why I assumed it was a cam chain but it could be echoing maybe?
Use a stethoscope or some other listening device to pin point the area in question .
Did you check/adjust your valves?
Are the header nuts tight? good gaskets.
On the '89, with your fuel pump off, there is a one way valve which should prevent fuel from flowing from your tank to the carb bowls (by gravity)
At the fuel pump, disconnect the fuel line output (line to the carbs) if you see gas dribbling out the fuel pump, there's your problem.
Also, as mentioned, time to clean your carbs and replace the float needle seat o rings....check your float heights.
charleygofast
All of Mark and Pats good advice :good2: and change that crappy gas infested oil if you haven't allready.
1984 Yamaha FJ 1100
1981 Yamaha XS 650
1985 Suzuki SP 600F
1979 Yamaha XS 1100        2015 Kawasaki KLR 650
Brook
..... bluezero,
was Cahill's the shop that you talk to??
If you can not solve the problem, Give Reed a call at Factory Four in Plant City  764-8373.
Reed is a very good motorcycle mechanic.
and If you made any Saturday nights runs, [about five years ago] starting at the...LOT.. in Clearwater. You may know him.
And just happens, he has a 88-89 FJ for sell.
roverfj1200
Quote from: Bluezero on January 09, 2015, 04:18:35 PM
From the front........ That will be a loose header and or header gasket.. Something to check.
1988 FJ1200
Richard.
Bluezero
Awesome thanks for all the suggestions guys. I'll start checking everything and come back when I figure out exactly what it is.
krusty
Surprised I didn't see carb syn mentioned or did I miss it? Unsynchronised carbs can result in a "rattle".
84 FJ1100 x 2
85 FJ1100
89 GL1500
60 Colleda 250TA x 3
63 Suzuki MD50
77 DT125E
77 DT175E
78 DT175F
79 DT250F
Bluezero
Well today I was able to change the oil and filter along with the plugs but didn't have enough time to learn how to check the valves. Anyways, I took a video so y'all can hear the noise. Thanks for the input. http://youtu.be/QV1gUpp9xjM
Nimbus
Well it kind of sounds like mine did last spring. Found #4 compression down to 50, ending up needing the valves lapped. :unknown:
JMHO
92 FJ1200
1953 Nimbus
1988 Honda VFR 400R
2018 Montesa 4rt
2003 Suzuki SV650S
1968 Honda CL450
1976 Honda CB400F
Bluezero
Damn -_- well I guess I'm doing a compression test this weekend thanks for the input.
