1174 overhaul
Started by theLeopard, January 03, 2015, 02:47:53 PM
theLeopard
I need to overhaul my scooter. It's time.
Can you guys pitch in to help me create a knockout list?
Heres what i have so far:
Piston rings&seals
Calibrate the cams
Compression test, &/or leakdown
Tighten chain sitting betwixt the 2&3 cams (whatsitcalled)
Front-fork seals
Clutch plates
Shift fork
Brake pads
Jets
Flapper valve
Cosmetics
I need to crack the motor open, thats what i really need help with. Blind in that department.
I know a guy who can help but he runs his own shop and his time is expensive.
I also need a garage.
If anyone wants to volunteer for this I'd limp it to yiur house once i get the parts squared. Knocking bad. Is my first rebuild :embarrassed:
1992 FJ1200
Here's the fork (& a knife too), I think you're done.
theLeopard
I havent heard the turn before, wats that mean?
Total loss? Or a complete list?
1992 FJ1200
That is a popular saying reference ..."put a fork in it cause you're done"
cooked
finished
it's over
kaput
hosed
screwed
"Dishes are done Man"
theLeopard
Why?
The scooter runs, just needs an overhaul.
1992 FJ1200
theLeopard
Ok i took my scooter to the doctor today and received a clean bill of health.
Engine runs "smooth as silk".
Chain is loose, so he showed me how to tighten the chain.
Already set for another oil change and basic maintenance.
So mebe you guys chip in some 30k tuneup ideas?
:music: it aint what it was anymore, george. Hopefully  :morning1:
1992 FJ1200
Well that's good.  I just got this stuck in my head. Its winter time up here.............. :drinks:
https://www.youtube.com/watch?v=j6zsUnkScEQ
Quote from: theLeopard on January 05, 2015, 03:52:07 PM
Change your fuel filter, it is under the fuel tank. use the real Yamaha filter.
then ride it and see if you can go 100mph now.
Dude, you are all over the map....what happened to the "serious" knock?
Quote from: theLeopard on January 03, 2015, 01:44:21 PM
I quartermiled a Mazerati. Lost on the freeway cause i havent jetted yet.
That was awhile ago, but i have a serious knock in my motor.
loud
Halp  :empathy: I'm worried.
theLeopard
Its still there but he said the chain might be slapping on the guard.
2inches of play. He rode it around abit, we revved it up inthe parking lot, some sustained 4&6k revs and a push to 8.
Is why i was shocked when tokd it was kaput, i rode 200 miles a couple weeks ago to LA.
Needs a tuneup badly though, thats why Im making this list.
I'll put fuel & oil filter on the list, Mark.
Might be a good time to replace my brake lines, Pat. I'll add that too.
1992 FJ1200
Burns
loose drive-chain/loose con-rod
  2 may Toe /2 Mah toe
theLeopard
whats a con-rod?
Pat, where do I find new brake lines? I can't find them.
$23:
89+ Undertank Fuel Filter; Yamaha 1200
Genuine Yamaha Filter
$6:
Hi-Flo, Cartridge Oil FIlter;
Yamaha FJ1100 - 1200, XJ1200 and XJR1300
$40:
FJ 41mm Fork Seal & Wiper Kit
$10:
Clutch Cover Gasket
$31:
EBC H/P Organic Brake Pads
88-92; FJ1200 Front Only
$34:
88-93; FJ1200 Rear Only
$12:
Magnetic Oil Pan Drain Plug
$1:
Engine Drain Plug Steel Gasket
$158
Intake Manifold Set
O.E. Yamaha 36Y intake manifolds; includes new o-rings.
Oval Side Panel Grommet
Round Side Panel Grommet
assorted nuts&bolts
Estimate: $315+ less discounts
1992 FJ1200
Burns
what's a con-rod?
a rusty vw Bug with a tube frame/slicks and a blown/NOX 12B
clear?
theLeopard
1992 FJ1200
Con Rod = short for connecting rod....
Spiegler, Galfer, to name a few....have brake line kits for your '92.
