Fj1200 Vibration
Started by wildfire, December 14, 2014, 08:52:35 PM
Forget about grips, sync's, vibranators, worn out mounts etc. there is a 99.9999% chance all your woes are coming from seized engines mounts.
Do as some have suggested, remove, clean up and lubricate them and you won't believe the difference, it's night and day.
Below 3500 rpm you can feel the motor working but I wouldn't call it vibration and above, turbine smooth. With seized mounts the vibes are terrible.
This is a well trodden path and those that have done it usually cannot believe the difference.
Bones
The bush that's sticking out and the collar it slides into is what needs to be cleaned and greased, but beware they can be hard to get out.
93 fj1200
79 suzuki gt250x7
Much better explanation than mine Tony........the pic brings it to life - so to speak.
Bminder
Quote from: Bones on December 15, 2014, 01:35:03 AM
And pay close attention to which bolt goes where etc. Both times I've greased them I seemed to get it back together wrong the first time.
Billy Minder
92 FJ1200 ABS
Yep, that's the same one Randy did for me. My rubber mounts were left alone.
wildfire
Great pic. Will help a lot. I might be able to try it tomorrow. Would moly grease be OK to use?
1992 FJ1200
It may be age  :empathy3:
Go ahead and lube up the mounts and sync your carbs again . If that doesn't fix it then you may have arthritis kicking in .
I have had to use the soft grips and vibranators and just added the handlebar risers to deal with mine. Got them from RPM Randy.
The vibranators made a huge difference for me . Most will not notice on short rides under a hour , but if you are out for a day of griping and twisting you will notice the advantage of them.
Yamifj1200
Take a good look at your chain and sprockets. A worn chain and old sprockets will make even the late models vibrate like crazy.. Take some time to make sure you don't have a dead link or two in your chain and look at the sprockets for tooth wear. Make sure your front mounts are greased and move freely, synch your carbs and check your chain and sprockets. Your late model should be smooth as silk at highway speeds....
   Eric M
Quote from: wildfire on December 15, 2014, 01:58:41 PM
One member even went as far as doing this and swears he can feel the difference after it's annual / 15,000km lube.
wildfire
You were not kidding. How do you even go about removing the bushing?. I have removed removed the bolts and the bushing is flush with the collar. Do I need to remove anything from the rear of the bushing?
1992 FJ1200
You'll need to fashion a puller. A deep socket the same diameter of the outer sleeve with a couple washers and a threaded rod with nuts on each end should work.
Your question is the reason we built the Maintenance Files: http://www.fjowners.com/index.php?topic=3613.0
wildfire
1992 FJ1200
wildfire
Ok so I dont want to risk causing damage. I just got back from Home Depot with the necessary parts to make a puller and I have run in to a problem.
In the link below there is a picture where a mirror is used to show the back side of the bushing and collar. However on my bike there is another bracket and a rubber mount . Obviously it needs to be removed/moved to enable using the puller. I have tried rotating but no luck.
I will try to get a pic  to explain what I am talking about .
1992 FJ1200
