Fork Protectors
Started by ken65, November 15, 2014, 07:33:04 PM
Quote from: Capn Ron on November 15, 2014, 08:30:27 PM
It's snowing at Alan's house...what else does he have to do?   :biggrin:
Yup!   :unknown:
ken65
Ok here's a pic of them, the internal measurement of the pipe was about 53mm from memory. I cut out abit of a slot so they can slip over the stanchion then onto the slider, its a firm fit but i will still use a zip lock on them.  I cant test it yet as i dont have any brakes on the bike, but will report back.. I may have to modify them to work ,worst case scenario ive blown 20 cents worth of pipe..
FJ1100mjk
Quote from: ken65 on November 16, 2014, 03:26:54 PM
I cant test it yet as i dont have any brakes on the bike, but will report back...
I wouldn't let that stop you. No pun intended.
Brakes, are highly overrated.  :smile:
Iron Balls #00002175
www.ironballs.com
ken65
you were right Tony, didn't even look like working . Anyway i couldnt be bothered experimenting. For now i will track down an old fork gator like this , cut it in half and put half on either side.
ken65
Thats an interesting concept Fred, hard to tell but the protector bit would be about 2" or so. They'd have to work, .  Might trim mine after all and see.
ken
skymasteres
Oh wow. Those are brilliant. I don't know about the quality of the oil seals, but that dust seal is kickass!
I case everyone forgot, RPM has them in stock; RPM fork protector
Randy -RPM
ken65
i think the ones that fred put the link to are the fork protector which is incorporated with the dust seal, not just a stand alone fork protector that you sell..
ken65
I cut another 1/2 " off the top of my pipe ones, made no difference.  Stupid bloody things..
Bones
Ken, If you trim them back so they don't go around the fork so much they should be ok. You only basically need a flat part on the front for protection and that'll clear the triple tree on suspension compression.
93 fj1200
79 suzuki gt250x7
ken65
ok tony, i understand were your coming from, i'll give it a crack tomorrow and see how it goes..
ken.
as an aside..  i was told that my bike looked like it was down low on the rear suspension.(FAT PRICK). Alas i adjusted my rear from 2 to 5 and it sorted most rear end hassles that i'm aware of... .. then i fitted new front fork seals and new 10w fork oil. . the black sludge that came out of the sliders felt like a slap in the face to me in as far i really need to up my maintenance regime, as  just with couple of adjustments my bike has been transformed.
ken65
well Tony i took your advice about narrowing the front,,, ,   it works well,    i will post up some pics just later, waiting for the paint to dry... with your brains and my looks, we could corner the south east QLD market.. then the world....ha
Bones
Hahaha, my brains and your looks, mmmm......... I think we both need a lot of help in those areas Ken.  :biggrin: Glad you finally got them worked out.
93 fj1200
79 suzuki gt250x7
