Go-to Chain Lube - What's Yours?
Started by FJ1100mjk, October 19, 2014, 08:28:24 AM
novaraptor
Let the flames begin... I use only WD40. Available anywhere, yes there is fling, but it does do a good job of penetrating into the chain. Of course, the debate is whether it is even a lubricant. I lube up the chain nearly every Friday, especially if I'm riding over the weekend.  Over the last year, I've adjusted it for slack once, and had the rear tire changed, so again an adjustment, though I wasn't present. I check for tightness and slack when oiling, and notice no ill effects, and never any binding. I think the main thing is: lube the chain regularly. I have heard good and bad about chain waxes, and I'm not inclined to use them, due to the sand and grit issues. Just my couple of centavos.
1990 FJ1200
Bearly Flying
I know it's an old thread, but I also use WD40. it is a water dispersant that will help prevent water from contaminating the factory lubricant inside the sealed pins, and also cleans the grit off the exterior of the chain.
It's easy to spray down the chain after a ride, not that messy for the next ride. I have had pretty good chain life on My FJ after switching to D40 rather than all the Snake Chain Oil's I used to try. YMMV....
Don
85 FJ1100  1250 big bore kit, ported, cammed.... Hooligan Bike
05 FJR 1300  Aux Fuel Tank, Russel Seat  Long Distance Bike
And a whole whack of RC Aircraft
FJ1100mjk
Good for you. Whatever you're happy with and works for you.
I just bought a can of the Motorex Road Strong lube http://www.revzilla.com/product/motorex-road-chain-lube that someone had earlier endorsed, but I have yet to try it out.
Iron Balls #00002175
www.ironballs.com
I have been using the Tri-Flow that Randy sells. works good .
I have been using Dupont Chain-Saver wax based with Teflon for awhile. I do have a can of Tri-Flow that I will be giving a try.
Quote from: Mark Olson on April 26, 2015, 08:08:21 PM
+1 cleans off easy and lubes the chain...
