Flappendectamy
Started by Sabre093, September 21, 2014, 11:01:14 PM
Sabre093
I've got this problem....saw the pdf file on dissembly,not sure what I got to do to fix problem..
2009 FJR 1300
1992 FJ 1200
1987 FJ 1200 Sold
1986 FJ 1200 Sold
1985 Venture Royale
1976 GoldWing
1986 FZ 750
1986 GPZ 900
1984 Honda Nighthawk S 750
1982 Honda Nighthawk 450
Steve_in_Florida
Quote from: Sabre093 on September 21, 2014, 11:01:14 PM
Your question is rather ambiguous.
Is the problem that you saw the PDF, or ???
How is the issue manifesting itself. Does your FJ "sing" after a ride? If so, then you have to remove the little rubber flappers that are restricting the airway.
If not, then please restate your problem with a bit more detail.
`90 FJ-1200
`92 FJ-1200
IBA # 54823
Sabre093
It's dying like running out of gas...I am sure I need to do this and yes it sings too...I saw the pdf file on this but not sure what needs to be removed.
2009 FJR 1300
1992 FJ 1200
1987 FJ 1200 Sold
1986 FJ 1200 Sold
1985 Venture Royale
1976 GoldWing
1986 FZ 750
1986 GPZ 900
My money is on....either 1) Vacuum Petcock failing to stay open..or 2) a fuel line pinch from incorrect fuel line routing....
Do you have the rubber flappers on your '86? (I didn't on my '84)
The rubber flappers are on the '89+ fuel pump bikes. (I had them on my '92)
Regardless, if you have them, cut a pie shape notch out of the sealing surfaces or just remove them entirely.
I am with Pat, my petcock failed and gave me all sorts of problems. I did the Flapectomy and unknowingly messed that up as well. After I gave my petcock the suck test...  :shok:, yes I said it.... I knew the petcock had a vacuum leak. After I replaced it, I still had issues...  :ireful: :ireful: :ireful: Then at a West Coast Rally Randy got me sorted out and found my error. If you chose to remove the flaps, remove the entire white plastic piece that holds them. The V cuts will not work if you install the white plastic piece upside down...  :mad:
The Suck Test...
http://www.fjowners.com/index.php?topic=9787.msg95549#msg95549
