LED Headlight
Started by movenon, September 08, 2014, 07:13:21 PM
George, your headlight should shut off when the starter button is pressed....
Quote from: Pat Conlon on November 24, 2014, 10:06:50 AM
True...............Thanks Pat.
Yes it does. I forgot all about that. Mine does turn off when the starter button is pressed...........
Thanks Pat. I will check it out when I put the battery back in it. I didn't think it through all the way I guess. :sorry:  I just know the headlight would turn on with the ignition switch and did not observe it in detail while cranking.  I still think that I will put the European style light switch on just because I like the control.
Due to weather the FJ is pretty much down until March.  As soon as the garage gets clear of two other projects I plan on pulling the top end off to do some needed maintenance, at that time I will also dig into the switch change out. Thanks again Pat have and good Thanksgiving with the family.
