4000-5000 RPM glitch
Started by JPaganel, August 25, 2014, 09:21:33 PM
Just throwing something out there..... Being as this problem is on an 86' and gravity fed, could there be a pinched/obstructed fuel line? At lower rpm's the engine has sufficient fuel and once the RPM's get higher and the engine is demanding more fuel, there is starvation....
JPaganel
That's a thought. I'll check for hose routing.
It occurred to me that maybe I should pull out the choke when it does this, to see if there is any effect. And when I decided to try that it didn't do it the whole way home.
1993 FJ1200 ABS
1984 FJ600, up on blocks
I don't want a pickle
