Digital Tachometer
Started by aviationfred, August 20, 2014, 02:13:36 PM
ugh...  Did their tech-support offer any advice or thoughts on what's up?
'93 Yamaha TDM850 (x2)
'06 KTM 200XC
'43 BSA WM20
Quote from: Dads_FJ on August 27, 2014, 08:40:59 AM
But then when they shrug their shoulders
I called them yesterday and the tech I spoke to was not sure what to do. I am going to email them a copy of the OEM FJ wiring diagram and see what they can suggest.
Quote from: aviationfred on August 29, 2014, 11:25:05 AM
I tried wiring the tachometer like Dads_FJ diagram. No change in the rpm's.  :dash2:
My next avenue to wander down is to connect the tachometer signal wire to the grey wire coming from the Coil Pick up to the Igniter.
Fred - did you try reconnecting the blue wire?
After speaking to the manufacturer, a few inquiries to fellow forum members and trying a few different on the bike wiring options. It has been determined that the Intellitronix Tachometer WILL NOT work with our engines. I have researched and found a suitable digital tach as a replacement.
This one is programmable to your exact engine type. I got it programmed and set up, works perfectly and looks a lot better than the other one. I am mucho happy with this one.
Good work Fred.  Gets interesting breaking new ground  :good2:. Which manufacture did you use ?
Quote from: movenon on September 14, 2014, 08:34:47 PM
I used the Drift Iridium Red Tachometer http://www.digital-speedos.co.uk/red-display-drift-iridium-gauges-55-c.asp
I would not recommend this Tachometer mod along with the Speedometer mod as a go to gauge mod to replace failing OEM gauges.
I am extremely happy with the final results,  :yahoo: IMO the aesthetics are awesome.....but there is extensive modifying of parts to make it a success. There is also the cost, $345.00 for both gauges.
If any member wants to take the leap and go this route, PM me for installation details.
