Put on the Renntec rack...
Started by Bminder, August 05, 2014, 09:45:38 AM
Bminder
Yesterday my Renntec Luggage rack from Randy at RPM came.  Renntec's instructions were pretty sparse and used British phrases but this dumb Wyoming hick figured it out.
It said to remove the turn signal indicators so I cut the wires up under the seat and respliced them. In the process I saw how there are these factory plugs to unplug the wires so I didn't have to cut them... darn it!!!! Wish I had known that before I went snip snip.
Also had to muscle the rack to match up with the front brackets.
But now when I'm carrying stuff I won't mar the paint on the back fender...
Thanks Randy!
Billy Minder
92 FJ1200 ABS
JoBrCo
Show us what it looks like, a pic would be great.
Been there and done that, (doing things that didn't need doing). Live and learn, huh? It's an easy enough fix though.  When taking off my fairing I noticed Yamaha has a lot of those bullet style connectors for turn signals and other such things requiring two wires.
One of the things I plan on doing before trying to spark her up for the first time, is burnish all the contacts on all the connectors.  No doubt there is 19 years of corrosion on them, and intermittent contact can cause fires and failure of the part requiring the electricity.  Largely that's all our in flight tech did to "fix" things, simply re-seat boards and connectors, and, "viola," usually it fixed the problem.
I bet it's a great rack if as much went into it's design as in their engine guards, probably some of the best I've seen.
Enjoy!
FJ Forever!  :drinks:
JoBrCo
1985 FJ1100NC
"To 'truly' see the man in the mirror, the only way for the image to be clear, as the man then 'truly' grows" --JoBrCo--
'I only know that I know nothing' --Socrates--
Bminder
Here you go. My garage is a disaster area. The wife took over 3/4th's of it for her furniture restoration projects...
Billy Minder
92 FJ1200 ABS
JoBrCo
Quote from: Bminder on August 05, 2014, 10:07:57 PM
Thanks!  That looks great!  I've scarred the crap out of that little whoop-de-do, ski jump, flare, or what ever you might want to call it, in the back there.  I lost my Kryptonite lock storage bracket, so I stored it hooked through the metal loop on the back on my '85 FJ1100, and as it bounced around due to road conditions, it wore off the paint and dug divots in the plastic.  :dash2:  So now I'll have to do some plastic welding to restore the original contour, and then try and temporarily match paint until I can do an entire bike paint restoration.  I'm leaving that for a future project.
Later!
JoBrCo
1985 FJ1100NC
novaraptor
I do so love a nice, firm rack!!
1990 FJ1200
