Bringing baby FJ back to life
Started by JPaganel, June 27, 2014, 11:17:24 PM
JPaganel
So, as I posted earlier, I have acquired a non-starting, non-running FJ600 for a princely sum of $300 and I have started working on making it run again.
The previous owner said he cleaned carbs, but could not make it run, and then, it mystically lost spark.
My first order of business was to ditch the horrible oldschool glass fuse fusebox. Glass fuses in and of themselves are not a problem, but the Yamaha boxes used before mid-80s had really bad metal used for clips. This metal gets brittle, fuses get loose, and any attempt at bending the clips breaks them. Or, sometimes they just break on their own. FJ1200, to my knowledge, always came with the ATC fusebox that does not have these issues. So, I transplanted a new ATC fusebox into the FJ600 to match all my other old Yamahas.
Still no start.
So, I disconnected the black/white kill wire from the ignition box. This got me spark. This also tells me the problem is in the safety circuit, which is kickstand switch, clutch switch, neutral switch and the relay. So far I found the clutch switch wrecked. Not sure about kickstand switch or relay yet. I am hindered by lack of a correct wiring diagram, the ones in the Clymer manual don't match what I see on the bike.
Bike ran with the the safety circuit disconnected, but only at idle with the choke all the way out. Giving it any gas would stall the engine. I pulled carbs and found that the guy's idea of cleaning them was to wash out the bowls and strip some screw heads. First emulsion tube I pulled was completely clogged.
So far, I got some screws on order and I am trying to find a replacement clutch switch from some place other than UK. International shipping sucks.
1993 FJ1200 ABS
1984 FJ600, up on blocks
I don't want a pickle
Re: the switch you seek, I saw a couple fj600s at Sport wheels In Jordan yesterday while I was there...
Pics to follow.
'93 Yamaha TDM 850 (x2)
'94 Yamaha WR250
'94 Yamaha WR250
TexasDave
John couldn't you find an FJ project bike that would not take quite so much work?    :rofl2:   Happy I wasn't there with you as I would have spent all my money. Lots of old school projects waiting to get started there.  Dave
JPaganel
Quote from: TexasDave on June 28, 2014, 08:00:48 PM
They won't sell you a bike out of there. For sale bikes is a different section of the place.
They have a ton of stuff, but are horribly disorganized. They have no idea what they have on hand, and so if you ever call them, they actually send a guy out in the yard to go take a look.
1993 FJ1200 ABS
