FJ heat
Started by theLeopard, June 27, 2014, 02:37:45 PM
Quote from: JMR on June 27, 2014, 08:15:15 PM
Carbs sputter to a stop...like running out of fuel. Hard, sudden engine stops are electrical. Look elsewhere.
Agreed.  This is a good lead to follow.  Kinda hard to do remote electrical troubleshooting though ...
theLeopard
anyone know a good reference manual to guide me through electrical troubleshooting?
i haven't done this before and i don't quite understand everything they're asking me to do in the manual.
i tested the battery, it has juice.
i tested the generator with the motor running, and it puts out a bit more juice than the battery does alone which is nominal.
that's about the point where i stopped. i'll need to study the diagrams but i'm a complete novice with electrical stuff.
not even sure how to test the wires, do i punch the tips of the voltmeter through the insulator? how do i test the boxes/relay units?
i'd ask for a reference book out of respect, since i'd wager answering all my questions would be quite an extensive project for you guys.
1992 FJ1200
On the electrical note...... Here is what I would check.
1. Check continuity between the negative terminal on the battery and a good bare spot on the frame.
2. Check these connectors for evidence of broken wires, signs of over heating, and loose or broken pins. Repair as necessary.
   Main on/off switch
   Right Handle Bar switch assembly
   ECU (Electronics Control Unit)
   Ignitor Unit
   Both main coils
3. While you have each connector apart, Use a spray can of electrical contact cleaner and spray any dirt/gunk from the connectors.
4. Use dielectric grease. Put a dab on each pin and socket and then reconnect each connector.
5. Check your earth ground wire. The Brown wire coming from your horn button.
I hope this is helpful.
JMR
Quote from: simi_ed on June 27, 2014, 08:54:08 PM
Many times it is hard to find electrical problems even with the bike in front of you. :biggrin:
oldktmdude
Quote from: aviationfred on June 27, 2014, 10:14:11 PM
   Main on/off switch
   Ignitor Unit
   Both main coils
Fred has pointed you in the right direction. Another problem area that I had, were loose fuses. The fuse connector points can loosen over time and cause a temporary power-outage to critical electrical components. Start the bike and wiggle the fuses to check their connectivity. This problem can cause intermittent  stoppages which can be hard to diagnose.  Pete.
1985 FJ1100 x2 (1 sold)
2009 TDM 900
1979 Kawasaki Z650 (sold)
2001 KTM 520 exc (sold)
2004 GasGas Ec300
1981 Honda CB 900 F (sold)
