xjr engine swap
Started by slipperysteve, June 25, 2014, 08:31:11 PM
slipperysteve
Hi guys, does anyone know if a carbie xjr 1200 engine will fit in an 84 1100 or 86 1200?
Cheers,Steve
yes it will fit. it fits tight in the early model frames but once you learn the angle it has to go in  its fairly straightforward.
some modification of the countershaft sprocket cover will be required (have to cut the tail of it off)
the output shaft is longer than a stock FJ but this is a good thing. It will allow you to easily run a wider 17" rear wheel and have the sprockets line up perfectly.
5xb
And you will have to change the Pickup coil govenor, oil level Gauge, and neutral switch assembly with the parts from your old FJ engine.
Br. Benny
jareith91
im wondering can i fit an xjr1300 motor on my 85 fj1100 frame without extream modifications because i want to get this 1300 on my 85 bore it over, stretch the bike as well as install a turbo charger to make a very nasty streetable bike that can hit the strip an so i will know that most other bikes cant compare.
Quote from: 5xb on June 29, 2014, 01:03:15 PM
Br. Benny
85 fj1100 resto into  fj1198!!!! (-:
Terry in Australia
I've seen a 1380cc big bore kit that (according to the eBay ad) will fit the FJ1100, FJ1200, XJR1250 and XJR1300 engine. He's a US seller, the price is $799.00, but you'll need an FJ1200 (or XJR1250) cylinder block, larger sleeves, and some machining of your crankcases to make it all fit. Still, if you're going for all out power, you can't beat cubic inches! Cheers, Terry.  :good2:
http://www.ebay.com.au/itm/Legends-Race-Car-Yamaha-FJ-FJ1100-FJ1200-XJR1300-1380cc-Ross-Piston-Kit-83mm-/171224349558?pt=Motorcycles_Parts_Accessories&hash=item27ddc43b76
REV1
Quote from: Terry in Australia on July 07, 2014, 02:35:20 AM
That's 800 for only the pistons though.
Terry in Australia
Quote from: REV1 on July 15, 2014, 02:37:50 PM
That's right mate, I did say that you'll need sleeves and gaskets plus machining in some cases too, but what price performance? I'd love to have an FJ1200 with Hayabusa-like power? Totally unnecessary of course, but good clean fun.......... Cheers, Terry.  :good2:
FJscott
Quote from: Terry in Australia on July 19, 2014, 08:49:55 PM
I would rather have a 6th gear, or a REALLY tall 5th gear
