Reskinned the seat
Started by JPaganel, June 13, 2014, 04:22:04 PM
JPaganel
Last fall I got a couple of cracks in my seat after pressing down on it on a cold day. By now, one of the cracks developed into a largish hole.
So, I stopped by Joann Fabrics and picked up some marine-grade vinyl. This stuff actually seems to be rather thicker and tougher than the original seat skin. And, after some time with a heat gun and a stapler, the attached picture is the result.
1993 FJ1200 ABS
1984 FJ600, up on blocks
I don't want a pickle
Look dam good! Did you spray adhesive on too?
JPaganel
Nope. Just heat, pull and staple.
1993 FJ1200 ABS
TexasDave
Very nice job. How long did it take?  Dave
JPaganel
All told, it was about an hour, hour and a half, I think. Not too bad for my first time upholstering.
1993 FJ1200 ABS
From what i've read, adhesives kind of important. It stops the vinyl from creeping back and stretching. Oh well, it's cheap enough that you can do it again if you have problem.
JPaganel
The original skin wasn't glued. I figured this should last at least the same 27 years it did.
1993 FJ1200 ABS
