Aftermarket mufflers with the stock collector box
Started by JPaganel, June 08, 2014, 11:45:33 AM
JPaganel
I think my stock mufflers might be getting a little tired. One is leaking a little. Now, a nice full exhaust from Supertrapp or something would be the thing, but I have a few other things to fix first. So, the cheaper thing would be to get some mufflers.
I looked for this, but I'm not really finding much by way of info - what would it take to run aftermarket mufflers with stock collector? I am guessing that due to outlets being angled out a straight piece of pipe from there to the muffler isn't going to work.
1993 FJ1200 ABS
1984 FJ600, up on blocks
I don't want a pickle
There are Delkevic, Viper, and Beowulf slip-ons available new. I don't know how many other brands make new slip-on cans for our FJ's. As far as used cans go..... There are a few to look out for. SuperTrapp, Yoshimura, Devil, Kerker, Beowulf and Viper to list a few. I am sure there are other brands out there.
Here is a link for a set of Viper slip-ons.
http://www.fjcatalogue.com/catalog/item/7168849/7343251.htm
1990 FJ1300 (1297cc) Casper
JPaganel
Quote from: aviationfred on June 08, 2014, 11:53:57 AM
See, that's just what I was thinking - if there is a pipe that goes from the stock collector to some standard size, any slip-on would work. Trick is working up that pipe...
1993 FJ1200 ABS
redwolf50
Fillow the link and check the exhaust section...they have the adapter pipes listed too :pardon:
86 FJ 1200(sold)
2002 FXDL
1977 xlh (customized)
1965 Triumph tr6
JPaganel
Aha!
That is exactly what I was thinking of.
http://www.fjcatalogue.com/catalog/item/7168849/10051121.htm
I'm a little worried about what the shipping across the pond will be. Too bad Randy doesn't have those. Oh, well.
1993 FJ1200 ABS
Most any "good" muffler shop should be able to bend and swage some connector pipes for you to fit between the collector box outlets and the mufflers of your choice.  They may not have polished stainless or chromed tubing, but that's not really necessary.  A bit of hi-temp black paint will make them look just fine.
I would've figured Jamesearthdrum would've posted s pic or two by now...   :unknown:
He's got some nice 'busa (IIRC) cans mounted up on his '89, with nice midpipes bent by a local shop.
