84 1100- fairing scoops repair
Started by bigbore2, May 30, 2014, 07:19:03 PM
bigbore2
Got a fairing scoop that one of the plastic mounts the screw threads into [screw holding scoop to duct- there are 3 of them] is cracked and half of the mount is ready to fall off.  I would like to repair this with some kind of bonding epoxy? Then put some in the mount hole before i thread the screw back in to lock it together.    I assume it is ABS like everything else.   I also have several fairing cracks PO put in, and need to cut out a channel and repair the same way so I don't mind spending some money on product if i can use it for that also.
cclase
Hi!  Check "side cover fix" in maintenance section.  I ran across it searching on a similar issue.
Chris
bigbore2
Did a search for "side cover fix" in the maintenance section and only your post came up.
cclase
bigbore2
Chris- thanx a bunch. Sometimes i just need to led by the hand and shown.
cclase
Yea, me too!  Hope it helped!  Let me know if you give the abs goo a go and what kind of result you get!
Chris
