Please identify this loose cable
Started by CafeNervosa, May 26, 2014, 12:30:22 PM
CafeNervosa
What is this loose cable?
I don't know what this cable is for.  I cannot find it on the electrical schematic drawing.
Wire colors are BRN and BLK.
It is possible it is a trickle charger lead wire, but the prior owner did not mention that he added a trickle charger wire harness.  I guess I could test that theory, but the bike is not here with me.
The bike as a 1989 FK1200 California
Thanks in advance.
1989 FJ1200 3SK.-for sale-
2009 BMW F800ST
Prior bikes  1996 Virago 535 and a ~1982 Suzuki CSR 650
That is what is on my California edition 86'. It went to an electric valve that opened and closed for the charcoal-filled vapor-collecting canisters behind the oil cooler. It is switched with the ignition so it is a handy connection for accessories.
Yep...what he said.
My '92 has the same "connector to nowhere" and I pondered this for a while as well.  Intended for California models, it's just just not used on the non-California models.
I use it as a switch to drive 2 relays.  It is an ignition switched circuit and works great for that purpose.
Quote from: movenon on May 26, 2014, 02:00:45 PM
Just curious George.  :lol: which 2 relays are you running off of it?
Quote from: giantkiller on May 26, 2014, 03:58:40 PM
Heated grips and driving lights (of which are not installed yet).  When the ignition is off I want them both circuits off line.
The third relay is driven by my horn switch to the Hella horns.
Super clean George, I want ride with you, but not park next to you....  :biggrin:
Quote from: FJmonkey on May 26, 2014, 05:02:43 PM
No need to worry, George just snuck in a picture of the avionics panel in an F16.   :biggrin:
CafeNervosa
Since my bike is a California model, should this wire be plugged into the emissions device?
2009 BMW F800ST
Quote from: CafeNervosa on May 26, 2014, 08:19:10 PM
Do you still have it?
George's picture also shows the "field wire" red connector that's being discussed elsewhere.
Quote from: FJ_Hooligan on May 26, 2014, 08:58:34 PM
And the field wire did suffer some over heating of the connector.  When it is unplugged you can see the damage.  I changed out the regulator to an external unit.
No real damage.  Caught it before it was a problem because I installed a voltmeter in my panel last year and observed the charging voltage going up, I think it got to 15.2 volts when I changed out the regulator.
It's only clean because I can't ride it   :lol:  See you in a few days.
motohorseman
THANK YOU!!!!!!!!!!!!!!!!!!!!!!!!!!!!!
CafeNervosa
Quote from: FJmonkey on May 26, 2014, 08:35:13 PM
Yes, I think the California emissions control is still installed.  I have owned the bike for only a few months.
2009 BMW F800ST
