Some pics of my FJ1200 project
Started by dma251, May 23, 2014, 02:24:34 AM
As Randy pointed out, the center nipple is the gas inlet...it feeds the 4 carbs.
the 2 white T's where you have the Tygon lines are the fuel bowl vents.
Looks like you have fuel pump carbs....
Here is a picture of my 1990 FJ carbs. The two white tees are vents the metal one is the fuel inlet  :good2:
Note the one JIS POS screw has been replaced with a SS Allen head :)..
dma251
Excellent!   I really appreciate the headaches you guys saved me from!
My next q
1990 FJ1200 Cafe
dma251
I've been doing "forum-assisted" projects for the last 15 years.    None would have happened without forums and enthusiasts like this....
Randy - I am placing an order tomorrow for pod filters and jets.
1990 FJ1200 Cafe
dma251
Here's the results of my latest series of late-night drinking and smoking in Washington State.....
I made an instrument cluster out of a mount from a gas-turbine engine I had, and I bought 12v bulbs for the crazy little indicator lights that were on it.   They're surplus military, push-to-test, made from machined aluminum and have a mechanical shutter in them for dimming.    Just such a great example of design overkill at tax-payer expense.   I saved them knowing I would find the right project to use them one-day, and this is that time.
Gauge will be my iPhone velcro-mounted.  I also wired into the harness an iPhone charge cord to switched-power.
Also working on the headlight.  I have two more of these cool cnc aluminum mounts, and I want to integrate them into this somehow.  It's the bucket for a cx500 and the ring and lens from something else Stanley.   (I always thought that was an awfully American sounding name to be a Japanese lighting company....)
Also started ordering parts for the lithium-Iron battery I am building for it.  Don't know what to do about the tail yet.....
Maybe I'll figure that out over the winter.  I want  to learn how to copper-plate.....
1990 FJ1200 Cafe
This looks like it is going to be a real fun bike to ride,  :good2:
fj johnnie
Nice work!  Like how you are reusing parts and materials from completely different purposes
Keep up the good work !
big r
Looking good. What is in that bucket, looks like rat was there :rofl2: :rofl2:
dma251
Quote from: big r on July 25, 2014, 11:41:19 AM
I think you are referring to my scrap wiring tub.  Its all the harnesses I've collected over the years.   I keep lengths over about 1' and most of the time can match up color/stripe colors exactly.   This bike has required major surgery to the wiring harness, and if I had known what was ahead, I would have just started over from scratch.   One of the issues is that the components (ignitor box, relays, fuses, etc.) were scattered throughout the length of th bike, so I had to relocate everything to one side of the harness or the other.  I also reduced its complexity significantly.
One of the complications is how I was going to use two-wire trucklite LED clearance lights as running/signal lights.   I had to add two relays to be able to accomplish both functions.   That added to the mess...
One thing I am considering is rewiring the run/kill switch to act as an ignition/main power switch.  This way I can delete the ignition switch and maybe later install a hidden toggle as a security mechanism.   Theft is not an issue where I live, but the next owner may want a little security.
1990 FJ1200 Cafe
I think your project looks great.
About your idea of a hidden "security" toggle switch for the ignition.......
My first bike had no keyed ignition switch, just a fork lock.
I added a "security" toggle switch hidden up under the tank.
Then I went to my job which was at the Ford Utica trim plant NE of Detroit.
When I finished work at about midnight, I went out to my bike, brushed the light dusting of snow off the seat, and proceeded to kick it for about 1/2 an hour until I remembered my new hidden switch.  :bad:
It started with the next kick.  Boy, was I dumb back then.
Quote from: Arnie on July 25, 2014, 09:12:38 PM
........and proceeded to kick it for about 1/2 an hour until I remembered my new hidden switch.  :bad:
Arnie, that must have been the Norton, it would take that much kicking before realising something was wrong and not just normal starting procedure. :biggrin:
Quote from: ribbert on July 25, 2014, 09:37:06 PM
Noel,
You malign the mighty Norton unfairly when the real culprit which causes hard starting in Nortons is the Luke'sAss electrics.  Once I'd replaced the Lucas coils with K-mart branded Chevy V8 coils, my Norton would start 1st or 2nd kick (as long as you kicked it properly).
No, the bike in question was a Bultaco Metralla 250.  It had "Femsa" ignition pieces (think poor quality Luke'sAss) and genuine Luke'sAss lighting bits.  It was not a "hard starter" when right, but could start backwards if the timing was a bit off.
Anyhow, the switch was installed on the Bul.
dma251
Today I received the diodes I needed to tie the right and left turn signal indicator wires together on one indicator lamp.    Still haven't received the special midget-flange 12vdc bulbs for these indicators.   One of the neatest things about these little indicator lamps is that they have a mechanical aperture shutter that can mechanically dim the light.   Something I love about military surplus - Since the taxpayers were paying, everything is of the highest quality.  These little indicator lamps came from a sweet little gas-turbine APU for starting jets.
The cost to the taxpayers for these little jump-starters was only $28,000.
1990 FJ1200 Cafe
