Sending Units
Started by Burns, May 08, 2014, 02:37:45 PM
Burns
I'm fabbing-up a dashboard to carry some instruments (volts, oil pressure, oil temp) and have no idea where/how to mount the oil temp and oil pressure sending units.
Anyone here been there/done that?
All suggestions deeply appreciated.
Quote from: Burns on May 08, 2014, 02:37:45 PM
Search for posts from skymasteres, he made a dash for his extra bits....
Here is the oil galley adapter needed for the sending unit mounting for the engine.
http://rpmracingca.com/proddetail.asp?prod=Engine%3ARPMMGP
skymasteres
If you get a couple of Randy's galley adapters you're all set for mounting the senders. Then it's just getting your wires up to the triple tree.
Here's my Mark I panel http://www.fjowners.com/index.php?topic=7691.msg100487#msg100487
And here is the Mark II http://www.fjowners.com/index.php?topic=7691.msg101945#msg101945
I'm currently working on the Mark III panel.  :wacko2:
Burns
GREAT.  Thank you all very much.
JMR
Don't know how the CB engine got in there
A million dollar CB engine no less.... :good2:
Hey Mike, re: oil pressure gauge: at idle on a hot engine, how much oil pressure does your gauge show?
I bet it was alarming the first time....
JMR
Quote from: Pat Conlon on May 11, 2014, 03:33:39 PM
That's a good question Pat....not very much at all. :biggrin: The oil pressure gauge is an electric sender unit which makes it a bit less accurate than a good mechanical piece BUT regardless it is low ( like 10 or 15lbs if lucky) when that oil is hot and thinned out. I just started the FJ today for the first time this season and it goes to 75lbs when cold with 20-50W.
