Jnimbostratus Street Fighter Project
Started by jnimbostratus, March 31, 2014, 09:42:20 PM
You must get a hell of a a breeze in the cabin with that big 'ol scoop up there.  :biggrin:  :rofl:
~JM~
Well... How come that front wheel is still on the ground?
jnimbostratus
Cuz the weather has been garbage still haha and I got moved to overnight shift at work abd I'm having a hell of a time adjusting.
~JM~
I can understand that. Our weather has been mixed, but not too bad for this time of year. I used to work a 12hr. rotating shift for about 15 years. It can be rough.
jnimbostratus
Wrapped the exhaust and painted the intercooler black.
~JM~
That IC looks much better black.
I installed an oversized IC in front of my radiator on my turbo Buick. It is aluminum with an aluminum looking finish. I had thought to paint it black so it wouldn't show up through the grill. I was warned that the paint would act as an insulator & that the heat transfer would be reduced. Don't know if this is true or not.
jnimbostratus
took the bike home yesterday. It feels great when I took the exhaust off to wrap it I found 2 leaky spots on welds that I sealed up and made a huge difference in spool time.
jnimbostratus
New smaller rear sprocket to more utilize the turbo. Also almost new used tires. A little bit fatter in the rear.
This is my second favorite build on here - first if you consider this one is "done"!
How's it running?  Have you got the fueling sorted well enough to let it rip?!
I really like the straight forward no-nonsense way this was built - well done
jnimbostratus
Thanks bro. The fueling is good It cranks like a raped ape. Drl400 is in the mail. Clutch is going to be my next step. And no this thing is far from done.
~JM~
I'm thinking that a rear wheel hugger fender would look good... If it doesn't melt. You're going to end up with a black stripe on the back of your riding jacket.
jnimbostratus
Put a few hours on tel bike today and a rear hugger is not my first concern. My clutch is..
~JM~
Quote from: jnimbostratus on April 02, 2015, 06:25:47 PM
...And shortly after a new clutch, you'll need a new rear tire. :biggrin:
