CDI wiring
Started by redeemed, March 11, 2014, 03:23:48 PM
redeemed
Hi All
Just bought a 84 FJ, was standing for a couple of years.
The dogs chewed of all the wires. So i'm splicing.
In need of a wiring diagram for the 4point connector. There is a orange, black and grey wire that needs to go into the 4pointer.
Thanks
H
Welcome, I think the CDI wiring diagram has been posted a few times. Try the search function and also try the files section, it may have been posted there. Lots of good stuff in the files section. When you have the time, why don't you find the introduction section and tell us more about our new member. We like to hear how others came to be FJ owners.
Quote from: redeemed on March 11, 2014, 03:23:48 PM
Hi All
Thanks
H
I don't have the full answer for you as I have a newer model.  But in an effort to get you started and to help someone else that can can look at there 84 pin layout on the connector  I will post a pin lay out picture from another member so you can use it as a reference point.  The photo is Medrider's. TNX Medrider  :good2:  The picture is for discussion of the pin layout only. So another member with an 84 can reference it.
Those wires are the control signals from the ignition pick-up's.  Black is ground and the grey and orange are from the 2 ignition pick ups on the lower left side of the engine.  I will keep digging but that's all I can contribute at the present.
mr blackstock
Hello,
I do not have a wiring diagram for the 85 FJ1100, but there are some for the fj1200.
http://www.fjowners.com/index.php?topic=9216.msg87299#msg87299
I hope it helps...
cheers, Gareth
Yamaha FJ1100 1985
mr blackstock
G'day,
I had a quick look at the ignition box on my 85' FJ1100.
Using the picture supplied by Movenon, the following colours match the numbers:
1=orange
2=grey
3=black
4=no wire
5=red/white
6=black
7=yellow
8= no wire
9=orange
10=grey
Hope it helps...
cheers, Gareth
Yamaha FJ1100 1985
This may confuse you and me! I have a 85. It was made 8/84. I have a 1100L  owners manual and heres a shot of the schematic in that area
What confuses me- now that I'm trying to help is that the wire colors on the schematic don't match what I have on the 6 pin.
This is both sides of the 6 pin
This is the 4 pin and it matches the schem.
