hub width
Started by chiz, March 09, 2014, 03:13:51 PM
chiz
If anyone has the time and opportunity I need to know your hub width of the later FJ 1200 hub the measurement taken from the backside of the disc to backside of the other I think.
Chiz
Country Joe
Chiz,
I just checked the width on the FZR 1000 wheel I have the in shop, it measured 4.723" across the rotor mounting surfaces.
1993 FJ 1200
Country Joe
Quote from: chiz on March 09, 2014, 03:13:51 PM
Chiz
I think I'd better ask, were you referring to the front wheel? Or were you asking about the rear wheel?
1993 FJ 1200
chiz
OOPS sorry front wheel
Thanks
chiz
Joe  It would appear you have the identical rim as I do. Was wondering how this width compares to the later 1200 hub.Wondering because all it would mean is to find the right discs and they would line right up with correct axel spacers to the calipers. yes?
Country Joe
Chiz,
The brake rotor mounting surfaces should be the same distance for the later model FJ wheels and the FZR 1000. The FJ 1200 rotors are the correct rotors to use, the FZR rotors are ,320 mm od, the FJ are 298mm. The 1987/1988 FZR wheels are the only ones to use the correct bearing ID  to make them a direct bolt on.
1993 FJ 1200
chiz
Quote from: Country Joe on March 10, 2014, 10:50:49 AM
Chiz,
Great this is what I have been digging for all this time thanks a bunch.
   Chiz
