Whinning/howl speedo/speedo cable?
Started by pevers, January 18, 2014, 12:39:51 AM
pevers
Hi!
My 1985 FJ1100 (100,000km) has started whinning(!). It appears to be coming from the speedo. I've seen some posts about this but I'm not clear if changing the speedo cable will stop this or if the problem is actually with the speedo itself. In which case a new cable won't help. There's no whinning when I take out the cable so I'm fairly certain it's that or something it's attached to!
Any suggestions?
It's the speedo death howl. Unhook it asap, you might be able to send it in for a rebuild.
See the Files.
Quote from: Pat Conlon on January 18, 2014, 01:09:10 AM
See the Files.
X2!
When the canary dies it usually takes out the speedo cable too...damhik...
I've also seen a speedo gear box (at the wheel) that was stripped too - wonder if the canary took it out too?!
Quote from: andyoutandabout on January 18, 2014, 07:26:59 PM
grease is the word
Yea, that's the ticket...drill, tap and thread on a zerk fitting on the back....and pump it full of lithium... :dash2:
Oh you silly goose, no amount of grease will stop the death howl. The internal gears need to be replaced.
pevers
Thanks guys. Unhooked and all is quiet! No noise from the front wheel take off so it must be all in the speedo. Oh, well I've only got here for another five months! I'll use the sat nav until then.
My speedo on the87' only howls when it is cold outside. After about 5 minutes of riding it stops howling.
1990 FJ1300 (1297cc) Casper
pevers
Hi Fred - certainly wasn't cold in Australia this last week!!
Quote from: aviationfred on January 19, 2014, 04:02:45 PM
It will degrade and eventually not care about the cold. Consider sending it to San Diego for a rebuild. Or if you have any spares on the shelf then you can wait.
Quote from: pevers on January 18, 2014, 12:39:51 AMHi!
Any suggestions?
Pevers,
Sometimes you can find a good instrument cluster on FleaBay, or in the Classifieds here.  The 1984 and 1985 FJ1100 speedometers are the same part number.
When my FJ1100 speedometer started howling, at least in my case, it could be fixed.  I took off the speedometer cable at the instrument and at the front wheel, and set it aside. I removed the air scoops, and bolts 8 & 14 on this Parts Page:
http://www.2wheelpros.com/oem-parts/1985-yamaha-fj1100n-fairing-1-assembly.html
You need to unbolt the headlight adjuster bracket, and  enough of the hardware to pull the headlight/instrument cowling forward slightly.  Flip the cowling inverted, tailend-over-headlight.  I had to cut some cable ties, but did not unplug much, if any, of the wiring  Support the cowling comfortably there somehow (I used straps to a stepladder), and re-install the speedometer cable to the instrument.  Remove the center speedometer drive line from the housing, and shoot about a tablespoon (10cc) of LIQUID lubricant down the empty speedometer cable housing.  I used ProLong (magic stuff in a spray can, from the automobile parts store) but probably any fine liquid petroleum lube would do the job.  Do NOT try using grease, silicones, or WD-40 (which is not a lubricant).  Wait half an hour, then slide the speedometer drive line back into the speedometer drive cable housing.
Let everything sit for an hour, with the cowling inverted.  Then, remove the entire speedometer drive cable (which may be a bit messy now) from the instrument.  Flip the cowling upright, install the speedometer drive cable, re-assemble everything,  and you should be good to go.  Do not overdo the lubrication there, or it may spill into the face of the speedometer, and that mess would be fairly tricky, to clean up.
This repair did the job for me, and two years later, I still have an accurate speedometer and no howling.
Quote from: red on January 19, 2014, 08:04:37 PM
Doesn't sound like something from an "AUTOMOTIVE" store to me!  :pardon:
Quote from: fj1289 on January 19, 2014, 09:47:04 PM
Quote from: red on January 19, 2014, 08:04:37 PMI used ProLong (magic stuff in a spray can, from the automobile parts store) but probably any fine liquid petroleum lube would do the job.
FJ1289,
You, sir, are going to grow up to be a Dirty Old Man.      :yahoo:
Quote from: FJmonkey on January 19, 2014, 07:42:59 PM
I do have a complete spare set of instruments,
Quote from: aviationfred on January 19, 2014, 09:58:42 PM
You do mean FJ instruments  right....  :shok: The topic seems altered a bit, I just want to be sure.... It might get awkward going forward....
When I bought the 87'. It came with a box of spare parts. A CBR600 shock, clutch pack, pressure plate and basket, Complete instrument cluster, complete wire harness, one OEM mirror and a few other items.
