Front Brakes FJ11
Started by homerfj1100, January 03, 2014, 03:00:06 PM
homerfj1100
For the past 2 years I have owned 2 very nice, polished aluminium adapters. These allow me to bolt 'blue spot' calipers to my '11. I also have the calipers. I have 3 metres of ss cable. I'm only interested in the front brakes. I want to keep the anti-dive. What connectors (banjo's, olives, washers etc) do I need to buy? I am 'intelligent' but I can't figure it out. Thank you. Tony
Homerfj1100
I believe for each caliper/anti-dive unit you should need a Double length banjo bolt to attach the brake line and anti-dive line to the caliper. Run the anti-dive line forward the the anti-dive unit and use OEM bolt to attach the line.
1990 FJ1300 (1297cc) Casper
homerfj1100
Thank you. However, like Watson, when he's with Sherlock, I am limited in my understanding. Say, 3 yards (US) of hose, blue spots, and the adapter plates. Keeping the anti dive. Just go through it, (again) as if you were talking to an ignoramus. Please. I need to get it right. Thank you so much.
Homerfj1100
Here is a link to a pre-made braided brake line set. I use this brand on my 89' 3CV.
http://www.ebay.com/itm/Goodridge-Yamaha-FJ1200-ANTIDIVE-86-87-Front-Braided-Brake-Lines-Hoses-/290935899997?pt=UK_Other_Clothing_Protection&var=&hash=item43bd21875d
There is a fellow member who is also near you. He is very knowledgeable and may be able to give you some advise personally. Member name  'Alf'   from Tenerife, Canary Islands
Here is a diagram of the OEM brake lines.
Hope this helps.
I'm still trying to figure out why you'd want to keep the 'anti-dive' 'functional'...      :scratch_one-s_head:
Quote from: not a lib on January 03, 2014, 06:43:53 PM
It would be nice to have a functional anti-dive system.  Shame Yamaha never made one for the FJ.
This would be a better option and you would have better handling and braking. Plus the blue spots bolt directly to the forks. You would be able the sell the fork/brake caliper adaptor plates and recover some of your expense.
Non anti-dive forks
http://www.ebay.de/itm/Gabel-front-fork-Yamaha-FJ-1200-3YA-/111249379824?pt=DE_Motorradteile&hash=item19e6fad1f0
17"x3.5" FZR1000 front wheel. Direct bolt on with no modification required.
http://www.ebay.de/itm/Yamaha-FZR-1000-1987-1988-Felge-vorne-Front-Wheel-201029177-/390530264117?pt=Kraftrad_Felgen&hash=item5aed6aec35
Dual line stainless steel brake lines.
http://www.ebay.de/itm/YAMAHA-1989-1994-FJ-1200-GALFER-BRAIDED-STAINLESS-STEEL-FRONT-BRAKE-LINE-KIT-/300865005606?pt=Motorcycles_Parts_Accessories&hash=item460cf3a826
Arashi wave rotors.
http://www.ebay.de/itm/Front-Brake-Disc-Rotor-YAMAHA-FZ750-FZS-FZR-600-XJR-TZ-250-TDM-TRX-850-FJ1200-B-/290931685599?pt=DE_Motorradteile&hash=item43bce138df
This is the complete front end mod for 84'-87' FJ's. You will be very pleased with this set up. Better tire choice, better braking and better handling.
craigo
When replacing brake lines, it is very important to use new crush washers on both sides of the hose fittings. The measurement is 10mm and can be bought at most auto parts stores.
And watch out for brake fluid on paint and plastic parts. It doesn't take but a few seconds to ruin your tank or fairing parts.
CraigO
CraigO
90FJ1200
homerfj1100
Quote from: craigo on January 04, 2014, 12:33:48 AM
CraigO
I will be careful, although the bike is old but still good looking. Local autoparts store here is, well....rare and a bit like waiting for food in a ´´cold war´´ Russian shop......nothing on display. Tony
Homerfj1100
homerfj1100
Quote from: aviationfred on January 03, 2014, 05:51:53 PM
He is indeed and is in contact. Thank you so much for the diagram, I shall print it. I have trouble ´´seeing the finishd result´´ and seeing it in 3D. Useless trying to learn the structure of the Double Helix. Tony
Hope this helps.
Homerfj1100
homerfj1100
everything
It´s ´´áesthetics´´ I saw one many years ago with  fitted in SS, highly polished. Functional ( or not) it looked good. Tony
Homerfj1100
homerfj1100
Quote from: aviationfred on January 03, 2014, 09:55:13 PM
Non anti-dive forks
Arashi wave rotors.
Right, I´ll go through all of those links. I suppose I should keep an open mind. Thanks for that Fred.
Homerfj1100
craigo
Quote from: homerfj1100 on January 04, 2014, 01:36:42 AM
CraigO
http://www.ebay.com/itm/10MM-BRAKE-LINE-BANJO-BOLT-CRUSH-WASHERS-HARLEY-/170881586126?pt=Motorcycles_Parts_Accessories&hash=item27c95613ce&vxp=mtr
They ship worldwide. I bought these exact same washers when I upgraded my calipers and master.
CraigO
CraigO
90FJ1200
Quote from: homerfj1100 on January 04, 2014, 01:43:10 AM
everything
Hey, it's your bike... it should look like you want it.    :yes:
homerfj1100
Quote from: craigo on January 04, 2014, 08:15:12 AM
CraigO
CraigO
Thank you. Tony
Homerfj1100
