Time for an oil change.
Started by Rat Fink, December 21, 2013, 06:19:47 PM
Rat Fink
I haven't had my bike for long.so decided to give her an oil change. Oh Dear is that the drain plug jammed very tightly above my Vance and Hines 4 into 1 ? Bother! so I have to remove the pipes to change my oil ? Anyone know a sneaky alternative?
Yes, there is an option. There is a galley plug you can remove and get most of the oil out. I am not sure which one it is. Others will need to offer up the answer you need.
Welcome to the asylum, Mr. Fink.
Quote from: FJmonkey on December 21, 2013, 06:26:59 PM...There is a galley plug you can remove and get most of the oil out.
No, there isn't a galley plug you can remove to drain the oil, sorry Monkey.
The option is; he can remove the left oil cooler line at the oil pan with the bike on the side side it is will drain the pan.
Quote from: racerrad8 on December 21, 2013, 06:34:16 PM
What Randy said, I knew something could be removed to drain the oil... Thanks Randy...  :good:
Rat Fink
Randy -
Thanks Randy all done. and in time to get in a nice ride. :good2:
