extending the swing arm
Started by CanDman, December 15, 2013, 09:00:06 PM
CanDman
Quote from: racerman_27410 on December 23, 2013, 05:11:10 PM
the FZ1 swingarm is definitely longer than the thunderace arm..... IIRC the thunderace swingarm is about 1.5 inches shorter than stock where the FZ1 arm is right at 2 inches longer than stock.
Merry Christmas and Kookaloo!
Hey Franky....Merry Christmas to you too......and thanks for the input......I hope we can meet up one day and let Brutus and CanD hang out and play......Kooookaloooo for sure
Kev
Merry Christmas Frank!
CanD's best solution may be to simply get and mod an FZ1 arm and sell the ready to install ThunderAce arm to recoup costs.  With a little patience, you could have a zero cost extension  :drinks:
Flynt
Quote from: racerman_27410 link=topic=10728.msg105045#msg105045 date=1387840270
URL=http://s47.photobucket.com/user/Racerman27410/media/IMG_0793.jpg.html][/URL]
Holy shit Frank... that thing of yours must be something else entirely from mine.  Mine has the T-Ace swing arm and is ok other than some level of throttle control in practice.  Yours looks like you might be able to get into the serious end of the power band   We're going to need to meet and compare kook zones at some point.
Merry Christmas and Happy Holidays to ALL!,
thanks fellas.... i should be more active now that my year long house building project is winding down (moving in Friday)
I'm definitely going to be doing more travelling this coming year and i hope to get up and ride with you all at some point soon!  :drinks:
Frank, Yes i can get into the power ...the longer swingarm alongside playing with the ride height to fine tune weight transfer allowed me to get the bike to really launch hard and still handle good in the twisties.
BTW my 18/38 gearing should be good for 200MPH + :gamer:
Kookaloo!
CanDman
Quote from: fj1289 on December 24, 2013, 08:20:41 PM
There was some material that needed removing to make room for the T-ace swing arm......what's involved in swapping over to the FZ1.....and what year?.......I already have the FZ1 front forks and the FZ1 tires.....so I like this suggestion the most.....
Kev
Quote from: CanDman on December 26, 2013, 09:15:16 AM
Kev
Kev, mine is a 2002 FZ1 swingarm (same as Franks I believe).
The wheel is centered in the arm, so its just a matter of removing ~2mm either side of the pivot. You have to press the bearings out first, and the original FZ1 spacer between the bearings.
Once you have measured and cut, you press in the bearings and use the OEM FJ bearing spacer, end caps and pivot bolt.
For the chain, I used the '86 Honda VF1000F c/s sprocket with the outside face machined off so that there is enough thread for the C/S nut and washer, and flipped the wheel sprocket......
And for the rear brake, you will need all FZ1 stuff, including hanger, calliper, spacers, axle and wheel.....and replace your OEM brake light switch (which will make contact with the swingarm) with a banjo bolt switch.
I also bought a pair of Soupys links to get the height where I wanted it.
Job done!
Take a look at mine in March mate.
CanDman
Quote from: Harvy on December 26, 2013, 01:47:05 PM
Kev
Job done!
I am looking forward to it Harv.....can I still use my Penske shock and my R1 brakes?
Quote from: CanDman on December 26, 2013, 10:15:46 PM
Yes and and yes Kev. I'm  also using a Penske and R1/FZ1 are the same calliper.
CanDman
Quote from: Harvy on December 27, 2013, 02:39:44 PM
I had no idea that you and I had so much in common Harv.....lets see
1. I have a 300zx tt......and you have one in your family
2. Penske shock
3. R1 brakes
4. an FJ
5. FZ1 fork mod
6. The same room at the rally
7. a love for Moose head and Whisky
8. a love for Coke .....(puzzles).... :mocking:
9. and we're both rabbits.....I was born in 63 (the ear of the rabbit)
TRULY AMAZING !!!!!!!!!!  :drinks:
Kev
skymasteres
Well, if it matters, I have a FZ1 swingarm that I'd be happy to trade for a Thunder Ace arm if you're interested...
fj johnnie
 My 90 also has the FZ1 2002 swing arm swap with the Penske shock. I also purchased the XJR clutch pushrod, shift shaft and counter shaft cover from Randy. Awesome set up. The longer wheelbase slows response a little but overall the bike rides and handles awesome. I am finishing off an 86 restoration now and have an unmolested low mileage 84 that will also get the FZ1 swinger and front end. I highly recommend that swing arm set up.
CanDman
Quote from: skymasteres on December 28, 2013, 01:39:31 AM
Hey Thanks Mav.......once I come back from Oz I will be in So Cal for a week....by then I will have seen Harvy's set up and maybe , if I bring a carrot, he may let me take it for a rip...and see how it feels...if I like it, I will seriously consider swapping swings..... :drinks:
Hey Johnnie....thx for the input..... :good:
Kev
