fender options
Started by FJscott, November 28, 2013, 11:40:23 AM
FJscott
I did the GSXR wheel mod, 3.5 x 17 front 5.5 x 17 rear. naturally the front fender tabs are
broken and I know I can ABS weld them however, is there another fender option out there?
the other thing is with the new tire( 120/60/17 conti-motion) having a lower profile the larger
distance between tire and fender looks...funky :negative:
not a single post 89' front fender for sale on the net that I could find and if there was I would
still have the gap. just by looking at the pics an early model FZ1 looks like it might work
Scott
Check on this thread using a Bandit fender http://www.fjowners.com/index.php?topic=10063.msg96828#msg96828
Also new front fenders are still available. Probably not the color you want but they are available. 70.00 - 140.00 range.
If you do a parts search check on an 84 -86 or 87 fenders they are the same fender, different colors... They will fit 89 and newer FJ's.
I don't know if this link will work for you but give it a try there are a couple of bikes here with Bandit fenders on.
http://translate.googleusercontent.com/translate_c?depth=1&hl=en&prev=/search%3Fq%3Dyamaha%2Bfj%2Bforum%26start%3D70%26sa%3DN%26biw%3D1366%26bih%3D597&rurl=translate.google.com&sl=de&u=http://www.fj-schrauber.de/html/werkstatt.html&usg=ALkJrhg20aj-Hv0NXqk61U_KajH06S_mFw
Let me know if you can figure out how to adapt a better fender. The FJ looks good but those tabs are a weak point. I rebuilt/repaired mine but wouldn't mind replacing it with something a little different.
Hope it helps out.
I know a few owners have used Suzuki Bandit front fenders.
Also there are a few used FJ front fenders at http://powaymotorcycle.com/gallery/yamaha/YamahaFJ1314.html
markmartin
Scott,  check out the first post on this thread. http://www.fjowners.com/index.php?topic=5770.15 I've had the fender on and off 2 times this year and it is holding up very well with no sign of cracks.  I think that Play doe would work for the mold.
Mark M
FJscott
Thanks guys, good info that helps a lot :good2:
Scott
FJscott
I put the RPM brace on but didn't put a washer in the space where the reflector tab was...Doh!
I should of picked up on that when I removed the reflector.
Scott
hein
Scott.
  If your looking for a 92-93 stock front fender I've got a brand new one still in the wrapper. $100.oo US plus shipping.
Hein.
Scott,
As already mentioned, the Bandit fender fits on the FJ with some modifications. Here is the photos provided from Antonn3 of his installation;
The new front portion of the fenders are readily available but just not is all colors anymore. They are currently only available in red (AJ) and a metallic black and I have them both listed here; Front Fender.
FJscott
Thanks Randy & Hein.
I'm liking the look of the Bandit fender so just ordered a pristine one off ebay for $39.
I'll have to paint it but Im painting the purple section of my 92 metallic black.
going with a black/silver with blue stripes to go with the Black GSXR wheels with
blue wheel stripe, blue dot calipers. Ill post some pics when completed.
Scott
Quote from: FJscott on November 28, 2013, 01:28:14 PM
Scott
On those Bandit fenders you might keep an eye out for the front fender extender they look pretty good.
