fj 1100 hardtail chop project
Started by 999chop, November 16, 2013, 03:07:51 PM
999chop
Standard Options omitted for clarity and demonstrated below.
Subject:
need help! i am trying to build an fj 1100 chop, using a hardup frame and a 1984 fj1100 as a donor. engine is mounted correctly .wanted to use xjr1300 front and rear wheels but when trying to line up the rear wheel the sprocket carrier is fouling on the frame, is there another wheel that would fit better .plus the front and rear sprockets dont line up .
The XJR has a longer output shaft than the FJ OEM set up. Other FJs have this fitted so there is an answer. I can't say as I am still on a stock FJ engine.
You know, this question is like asking...Help my bike is running poorly...what's wrong?  :dash2:
Some more information is needed.....Like....(with the back tire centered in the frame)...How much offset do you have...?
Flip the rear sprocket?  Mill the mounting face of the cush drive? Offset the rim in the chassi?
Look thru the files section at other rear wheel conversions and steal ideas for your project.  Good luck and post pics of your work!
999chop
cheers fj1289 thanks for this,your suggestion is a great help i will give this a try  :good:
