Clutch MC rebuid kit compatability
Started by Paul1965, October 19, 2013, 04:16:55 PM
Paul1965
Are any of the seals in the FJ1200 clutch MC rebuild kit compatible with the FJ1100 MC? Mine has developed a leak so I'm looking at resealing it (assuming of course I won't need any hard parts), but I really don't want to spend the money being asked for an FJ1100 MC kit.
1978 Yamaha 400 Sold
1984 Yamaha Maxim 400 Blew up
1982 Yamaha Vision Sold
1983 Kawasaki GPz1100 Sold
1984 Yamaha FJ1100 Killed it
1991 Yamaha FJ1200 Sold
2009 Triumph Sprint ST Sold
2014 Triumph Trophy SE
Quote from: Paul1965 on October 19, 2013, 04:16:55 PM
Nope, I have had several customer buy the 1200 kit for the same purpose and then return it because none of the parts, other than the dust boot were the same.
It is a completely different piston design.
Paul1965
Quote from: racerrad8 on October 19, 2013, 05:18:11 PM
Thanks Randy, I figured that would be the case.
Paul1965
I'm thinking about maybe just swapping in a used MC from an 86 or up instead. That way if and when I have to rebuild it I'm not paying an arm and a leg for a kit. Are there any issues I can expect with that?
KRATOES
Are any of the seals in the FJ1200 clutch MC rebuild kit compatible with the FJ1100 MC? Mine has developed a leak so I'm looking at resealing it (assuming of course I won't need any hard parts), but I really don't want to spend the money being asked for an FJ1100 MC kit.        your kit is $32.00@yamaha sports plaza :good2:
Quote from: Paul1965 on October 21, 2013, 07:52:26 PM
You will have no issues with swapping a 1200 master cylinder to your 1100. Direct swap, no modification required and the wires hook up the same.
I have a stock '89 m/c on the shelf... worked fine when removed, but you'd have to flush any remaining DOT5 out of it.
If you want it, just let me know.
Paul1965
 :wacko1: Uh, well I guess I forgot to post that I ended up buying a set of universals with urine cups to try out. Got the front brake one installed and bled yesterday (and bypassed the AD at the same time), will do the clutch next weekend.
