Ugh! Really bad news. I discovered my frame is cracked!
Started by Ack535, October 13, 2013, 10:14:42 AM
I bought my bike at very low mileage and stripped it right down (just the motor and wiring loom left) as soon as I got it home. The only thing I found wrong was the highlighted lower bolt sheared. You can still just see where the paint has rubbed off from the movement. I replaced it with a high tensile bolt and have had no issue since. Given my experience with FJ#2  I check them all periodically and nothing has changed in 75,000 km. Makes you wonder then why so many come loose or break.
I wouldn't be too worried about the frame alignment as it hasn't separated and it hasn't been in an accident. I believe with a bit of mucking around the crack could be drawn together prior to welding.
Bozo
Have you checked if there is rust internally causing the frame walls to turn paper thin, sometimes the outside looks new but the inside might have water, just a thought.
