Ebay brake and clutch master cylinders???????
Started by Motorheaddad, September 16, 2013, 01:57:47 PM
Motorheaddad
I'm thinking of buying these for my 84 FJ1100. http://www.ebay.com/itm/161034710091?ssPageName=STRK:MEWAX:IT&_trksid=p3984.m1438.l2649#ht_2042wt_1004
Both of mine are leaking and pitted so I thought these would be a nice replacement. Has anyone ever bought anything similar? I like the look of the "urine cups". I contacted the seller about the bore size but they don't know. Thanks in advance.
Quote from: Motorheaddad on September 16, 2013, 01:57:47 PM
The price looks good anyhow... I don't know about these units but sometimes the bore size is cast into the side of the cylinder. Might ask them about a rebuild kit ? Might give you a clue as to the size.
There may be a difficulty in connecting the brake lines. The banjo bolt ports are 90 degrees off from the OEM position. The OEM Banjo bolt ports face forward.
oldktmdude
   My opinion is "to steer clear". If the sellers don't even know what the bore sizes are, what good are they going to be if you have any problems with these units. Sure they are cheap but I place a high price on my safety, especially when it comes to brakes. There are plenty of other "tried and true" options around and I'd prefer to stick with one of them. Nissin make a good range of "urine style" masters, that are way more expensive than these but are far superior products. Used R1 and R6 masters are also a good and usually cheap option. My advice is to keep looking. Regards, Pete.
1985 FJ1100 x2 (1 sold)
2009 TDM 900
1979 Kawasaki Z650 (sold)
2001 KTM 520 exc (sold)
2004 GasGas Ec300
1981 Honda CB 900 F (sold)
Motorheaddad
Thanks for the info guys. I'll keep looking. I did find a 91 ZX6 clutch master for cheap. Will it work?
 The zx6 mc should work fine, most likely a nissin brand one too
Motorheaddad
Cool, off to Ebay I go to get the Zx6 MC. Thanks again to all of you for your input
Just don't buy the cable style one, , don't know why they bother going backwards in styles
I am going to give these a try on my 87'. Not this particular one but the same years and model. Honda VTR1000 Front Brake and clutch master cylinders.
http://www.ebay.com/itm/400547117470?ssPageName=STRK:MEWAX:IT&_trksid=p3984.m1423.l2649
Not sure what is up with the orange colored handle.
Quote from: aviationfred on September 17, 2013, 08:24:17 PM
That Orange is a slightly faded Red anodize finish. Aluminum that is died any color will fade with heat and age. It will eventually turn a pale Pink.  :bad:
