Oh dear!!
Started by Tom, September 11, 2013, 05:39:31 AM
Tom
Well looks like my FJ 1200 has become a long term project. Fuel pump went, wiring fried and now number 2 cylinder has lost compression!!!!!!! The rebuild begins...................
Quote from: Tom on September 11, 2013, 05:39:31 AM
That will be an interesting report. Never heard of an FJ dropping a cylinder. Any indications why?
Tom
No indication why yet, mainly because I haven't pulled it down yet, but, valve clearances are still good, cam timing perfect, oil beautifully brown, no blackness, cams clean and covered in oil, although I have been messing with the jetting and the plugs which were really black before, are now a nicer shade of unleaded fuel brown , so a piece of carbon may have dislodged and stuck to a valve (something I have seen many times before) I was hooking along two up when it started running odd the other day, either way when I get in there I will probably be doing a top end rebuild, after all it has done 138000 kms.... keep you posted.
chiz
Good to hear you got an OH WELL attitude(are you Canadian?). Same kind of thing happened when I got mine sitting for nearly 3 months still haven't be able to ride it.
Chiz
Quote from: chiz on September 11, 2013, 07:39:18 AM
Chiz
That would be a "WELL EH" attitude.
Tom
Chiz
Hey Chiz,
Australian actually. Having been a bike mechanic for 25yrs now, I tend to think, yep no worries, easy to fix. And having access to cheaper parts the cost isn't so scary. I will probably whip the top end off this week and start sorting what I need.
Sorry to hear about the problem.... Post some pictures when you get into the top end.
tmkaos
This is exactly the dame symptoms my '92 displayed at 140,000kms. Culprits turned out to be worn valve stem seals squirting oil into cylinders, and a slightly damaged bore on no. 2. I gave mine a hone, new rings, valve stem seals, new valve springs and relapped the valves and a quick port and polish. When I get it back together I'll tell you if it worked!
Story here, might help you avoid some of my errors.. :good:
http://www.fjowners.com/index.php?topic=7854
Good luck with yours!
James
'92 FJ1200 - '07 to present
'83 VF750S Sabre - '04 - '07
'87 VT250FG - '94 - '98
Tom
Quote from: movenon on September 11, 2013, 09:49:43 AM
I will attempt to George, my computer doesn't like my camera for some reason, so they may be slightly dodgy I Phone photos. I wanted to change my profile picture, but the only photos I have are on the camera.
Tom
Quote from: tmkaos on September 11, 2013, 01:17:43 PM
James
G'day James,
   When I get in there, I will also be cleaning and matching the ports up. Polish and radius the valves and what ever else it needs. I wouldn't polish the inlet ports, but will probably do the exhaust ports. Basically it'll get a top end rebuild.
Tom.
Tom
Head and barrels are off, sorry no photos yet,
L/H Number 2 cyl ex valve has a decent chunk missing?? Luckily, it seems, it went down the pipe! No piston or combustion chamber damage. So, it'll be getting pistons, rings, valve(s), stem seals, all gaskets and O rings, etc. Not sure about guides yet, haven't dismantled the head. I would say also it's the first time it's been apart as most of the head studs are corroded down a little - new ones coming also.
I'll try for photos this weekend.
Now where is that gasket scraper??
Tom.
tmkaos
Christ almighty you don't fuck around, it took me weeks to get to that stage..  :biggrin:
Tom
Quote from: tmkaos on September 12, 2013, 05:39:15 AM
Yeah, I must be mad. I spend all day working on bikes then come home and work some more!!!!!
Still, summer is a coming here.
Hell mate, when youve finished yours Sunday arvo, mind heading this way and sorting out mine  :biggrin:
Tom
Quote from: fj11.5 on September 12, 2013, 05:04:25 PM
Sure, 4pm OK??  :yahoo: It may take some time though to get parts, I am also trying to save to go to the UK next year.  I have some photos, just need to get them off my phone. Pulled the valves out today and cleaned them up. All inlets are like new. Found another dodgy ex valve so I am going to replace all the ex valves to be sure. Seats are looking good, but I will run the seat cutter over them before final lapping in.
