Your current milaege?
Started by Vsekvsek, August 17, 2013, 09:33:38 PM
NJona86FJ
87 model. Had 98 000 k's when bought at ipswich in 2009? Have put 108 000 on there since. Oil changes and barest maintenance. Comp down on every cylinder, smokes a bit, leaks, loses oil,rattles squeaks,needs a new seat, dropped ot a ehile ago. Has a new headlight bulb tho!! Champion TANK of a bike. Should fix er up tho. Sniffs. One day eh?
neil
W. Churchill
I've got a '93 with 105,000 km's on it. I bought it in the low 30's a bit over 4 years ago. It was 100% unmolested and in showroom condition under a substantial build up of grime. As soon as I bought it I stripped it down to the frame and loom to detail it.
It is on it's second motor while it's first motor gets it's second rebuild.
But hey, that's nothing, check out the mileage on my coffee machine.
If the bike and the coffee machine both died tomorrow, I'm afraid the coffee maker would be head of the queue.
That machine has only cost me $2.20 in parts and $6.00 for a part I dropped and couldn't find in all that time. If only bikes were that cheap to run.
Bozo
Had 163,000km when the engine was spiced up, apart from seals, starter and cam chains the bottom end was not touched (yes I know a bearing will drop one day and I'll remember my mistake). It didn't need to have the pistons done but I wanted more go (and got it in spades). Now it has 173,000kms plus. I don't consider this millage much for this motor as it appears to want to run forever (like my old Z1R). 250,000 plus would be my goal before anything will need re-doing (by that time I'll need bottom end work) :rofl:.
Quote from: Bozo on August 20, 2013, 02:44:43 AM
So, what did you do to get the extra grunt?
Bozo
Quote from: ribbert on August 20, 2013, 06:42:06 AM
Head shaved a bit, wiseco 1219, Megacycle mild street cams (fantastic cam, top and bottom end), port clean only, Marving exhaust (very noticeable increase in power fantastic pipe). The bottom and mid range is a huge improvement, went against a hayabusa 2010 model on top end from 90kph by 160kph he was about two bike lengths in front (after that I'd say he'll cream me), the only problem I have is the front lifts under power which can catch you out if negotiating a sweeper. The Limo (FJ) goes very hard to the rev limiter at 10,500rpm so I try to change at 10 but it gets there fast.
Bill_Rockoff
Bought an '89 new in June 1990, put 9,000 miles on it before it was stolen in 1991.  (22 years ago today.)
Bought my current '89 in November 1991 with ~1,500 miles on it, from John's (The Beer Scientist's) dad.  It now has 106,000 miles on it.
It smokes something fierce, especially on trailing throttle, and it leaks a good bit too (need to try again with that valve cover.)  One of these years, I'm going to pull the motor and send it to RPM.
fjrider1
130k + The speed cable came off and I didn't replace it for a few years. I've had the bike 25 years, no rebuild...
jscgdunn
Our little fleet (all kms):
92 ABS(less) 73K my daily driver (yzf 600 forks and wheels, blue spots, BMW shock)
92                70K my next winter project, stock
90                75K my youngest son's, stock
86                64K 1/2 owned with my mate below, kinda rough, (f4I shock, "newer" front springs)
84                63K my oldest son's (89 wheels and forks, 1KG springs, blue spot front brakes)
Mate's Bikes
89                62K stock
85                92K stock
84                71K stock
the fun never ends.... :mail1: :mail1:
90 FJ 1200 (Son # 2), Stock
Bill_Rockoff
Wow, you guys are your own FJ club!  Seriously, I don't think there are that many FJs at most rallies.
Quote from: Bill_Rockoff on August 24, 2013, 04:02:23 PM
Wow, you guys are your own FJ club!  Seriously, I don't think there are that many FJs at most EAST COAST US rallies.
FTFY.   :sorry:
jscgdunn
So here is a pic of the 85, the 89, 92 project, the 86, and my 92
One of the '84s in this one at our little "rally"....still tough to get them all together at once...even when Dad pays for the trip!  :good2: :good2:
Bminder
Bought my '92 beginning of June with about 65,000 miles on it, have put 1500 on it for 66,500.
Oil level has gone down only the slightest in that 1500 miles.
Billy Minder
92 FJ1200 ABS
FJ Flyer
118K miles on the FJ .  75K miles on the FJR.
Chris P.
'16 FJR1300ES
'87 FJ1200
'76 DT250
Wear your gear.
Charlie-brm
I guess my 84 is a pup with under 47,000 miles.
This is still only my second season with it. I'll try to do better.
1979 XS750SF - 2005 to 2012
