Gixxer Rear Sprocket
Started by Sabre093, June 27, 2013, 05:28:50 PM
Quote from: eeshed on July 14, 2013, 01:56:57 PM
Thanks for the great information. I'm on a mission to collect all the parts for a gsxr wheel conversion. I will need a 38 teeth sprocket. However, I would like to get a steel, and not aluminum.
I wasn't clear if the link above is for a steel or aluminum. Could you please clarify? If it is aluminum, any suggestions for where I can get a 38 teeth steel sprocket?
Thanks,
Eyal
Mine was a 93 GSXR 750 38 tooth JT Rear sprocket off  e bay for 39 bucks.  As a note I flipped my sprocket to end up with a near as I can measure a perfect chain alignment with the front sprocket. Motion Pro makes a 15.00 tool that helps in the chain alignment.
Sabre093
JTR816.38... That is part # for steel Sprocket
2009 FJR 1300
1992 FJ 1200
1987 FJ 1200 Sold
1986 FJ 1200 Sold
1985 Venture Royale
1976 GoldWing
1986 FZ 750
1986 GPZ 900
1984 Honda Nighthawk S 750
1982 Honda Nighthawk 450
Thanks,
Eyal
The eBay link I posted in a previous thread is for a STEEL 38t sprocket.
Here is the link again.
http://www.ebay.com/itm/JT-Rear-Sprocket-38T-Suzuki-GSXR750-1990-1992-/321106738641?pt=Motorcycles_Parts_Accessories&hash=item4ac373fdd1#ht_1691wt_1161
1990 FJ1300 (1297cc) Casper
Sabre093
I went thru Amazon got same one for 22 and all told 45 to my door..
2009 FJR 1300
1992 FJ 1200
1987 FJ 1200 Sold
1986 FJ 1200 Sold
1985 Venture Royale
1976 GoldWing
1986 FZ 750
1986 GPZ 900
I just ordered my JT Steel 38T sprocket from my local Suzuki shop. Only took them 3 days to get in, relatively inexpensive as well,    :drinks:
eeshed
Just got my 38T sprocket. Just to confirm, I would get a near perfect alignment if I mount the sprocket with the machined indented side on the wheel?
Eyal
