Dropped something in the tank
Started by chocker, August 06, 2013, 11:20:37 AM
chocker
Hi,
I was filling up yesterday and there were a couple of drops of gas that dripped on the tank. I took some paper from the dispenser at the gas station and it turned out that when I was wiping the excess, a small piece of paper fell in the tank. I stuck my fingers in to try to get it but too late. It was about 1 inch by 1 inch in size. My question is since it is a small piece and only single ply probably recycled, will it just disintegrate in the tank with the gas. Obviously nothing has happened yet. Of what I saw it seemed to slide in the opposite direction of the petcock. What do you guys think?
Thanks,
Mark
novaraptor
just my guess, but yeah, I think it will dissolve. To be sure, get some of the same paper in about the same size and let it soak in a small amount of gas and see if it softens up and breaks apart.
Nova
1990 FJ1200
novaraptor
Though, if you have a claw around, you probably should go fishing...
Nova
1990 FJ1200
Country Joe
Quote from: novaraptor on August 06, 2013, 12:43:15 PM
Nova
[+1 on that. I had the little paper gasket from the cap of a fuel treatment bottle fall into the tank. I ran the fuel pretty nearly empty and took the tank off so I could slosh it around to wher I could pick it out with a pick up claw.
1993 FJ 1200
Bminder
Like the other guys said, I would try to fish it out with a claw. If you don't have one, they are cheap at a parts store.
If you don't and it doesn't dissolve, it will probably just shrink up into a little clod and sit in a crevice in the tank. Doubt if it will cause any problems.
I had a moth fly into my tank the other day when I was filling it up.
Billy Minder
92 FJ1200 ABS
Paper products will dissolve back into the pulp used to create it when in water. Gas is not likely to dissolve it like water would. I would carefully fish it out if it were my tank. Keep a fire extinguisher handy any time your playing around with fuel.
Country Joe
Just a suggestion.......if you choose to use a flashlight to see what you are trying to fish out of the tank (and who wouldn't?), make sure you turn the flashlight off & on someplace other than in the fuel filler opening. Flashlight switches can arc when they are operated. It's probably not likely to be a problem, but why chance it?
Fish safely,
1993 FJ 1200
