Polishing the frame??
Started by thunder1295, June 22, 2013, 11:18:49 AM
Quote from: racerrad8 on June 22, 2013, 08:15:08 PM
Quote from: 1tinindian on June 22, 2013, 07:41:26 PM
Thanks randy!
Ebay search for 90 degree aluminum valve stems.
Leon, why did you go to eBay...
My feeling are hurt now.
90* Aluminum valve stem
No offence Randy.
I was trying to think where I bought the ones in my picture and they were off ebay.
I bought these prior to you having them listed on your site, if I remember correctly.
But now I seem to remember buying one from you to use in my spare rear wheel.
Sorry.
Quote from: thunder1295 on June 22, 2013, 11:18:49 AM
I was wondering what is coating the aluminum frame and swing arm, just can't seem to polish it up to a shine and is there
something that takes off that coating?
Jim
To answer you question about how to remove the coating on the swing arm, I actually started with a 24 grit wheel to remove the upper and lower ridge to simplify the polishing process.
I then moved to 80 grit on a DA sander to remove the rest of the finish and to smooth the welds.
Then on to 400 and 600 grit W&D paper.
Then the actual polishing process started with several different rouges and compounds until a mirror finish was achieved.
Finally finished it off by hand with Simichrome paste and a soft towel.
Easy peasy, lemon squeezy!
No worries Leon, I am just pulling your leg.
Quote from: racerrad8 on June 22, 2013, 10:19:48 PM
I know you well enough to know that, my friend! :praising: :drinks:
