oil filters
Started by big r, June 28, 2013, 03:14:50 PM
big r
I know, it's on here somewhere. I have been looking for the last 1/2 hour and can't find them. I need the part numbers for the oil filters. :flag_of_truce: :dash2: Could somebody please repost them for me. Thanks Big R.
big r
I guess I should have been more specific. I am looking for the filters thsat fit Randy's spin on adapter. Sorry about that. Big R
Here is the link for the K&N from Randy.
http://www.rpmracingca.com/proddetail.asp?prod=Engine%3ABOF&cat=39
the Wix brand link.
http://www.rpmracingca.com/proddetail.asp?prod=SpinOnOilFilter
Also, At most auto parts stores, Walmart, K-Mart Look 1988 Acura Integra 1.6L filters and you will be all set. (The Wix part number that Randy carries crosses over to identify it as used on the Acura)
Not to start an oil topic or anything like that . . .     :lol:
All oil filters are not created equal.  Some spin-on oil filters have an anti-drain check valve, so the filter stays full of oil when the engine is off.  When you start up, with these better oil filters, the engine gets full oil flow immediately.  Without that check valve, the oil pump has to fill up the oil filter, before the bearings start getting any oil.  A lot of engine-wear happens in the first few seconds, then, when the filter has gone dry.
I can't name every brand of oil filter which has the check valve, but WIX filters do have it.  A good parts-guy can probably tell you which brands of oil filter will have the check valve, also.
And if you are really analretentive about oil then check how well your filter cleans. Some are wide open while others catch some of the small stuff... [Stir the pot smiley]....
I use WIX or NAPA Gold (same filter mfg by WIX).  Spin on filter is the only way to go on the FJ... :lol: :lol:
HARTLESS
fram is probably the worst in my opinion....
6 oil filters cut open
here is a little comparison on the spin on filters...btw, I have a fram on mine right now....I wish I didn't, but its not the spin on type haha so its not quite as bad
craigo
Bosch 3312 on mine, works great.
CraigO
CraigO
90FJ1200
Ray, there is a list of filters listed on the installation instructions.
-OR-
I have the same list posted obn my website for the adapter; RPM Spin On Oil Filter Adapter
