rear axle placement
Started by bigbore2, May 29, 2013, 02:00:56 PM
bigbore2
[84-1100]  Can anyone see any problem if I reverse the rear axle insertion, put bolt head on right side and washer, nut on left side of swingarm. I am having muffler clearance problems since I did the rear shock swap. I have a 4/1 Yoshimira.
Or I could look at mounting the muffler outboard some to clear. But the axle switch would be easiest.
On every bike that I have owned, the bolt head was on the right side (rear brake pedal side). The nut on the left side (gear shift side).
Quote from: bigbore2 on May 29, 2013, 02:00:56 PM
Should not be a concern........ I had it thru from either side when I had OEM swingarm and had no issues.
oldktmdude
   I always fit all my bikes with the bolt head on the right side. It's easier to align the wheel because you already have the brake-arm held in position by the axle. That's my story and I'm sticking to it.   :good:   Pete.
1985 FJ1100 x2 (1 sold)
2009 TDM 900
1979 Kawasaki Z650 (sold)
2001 KTM 520 exc (sold)
2004 GasGas Ec300
1981 Honda CB 900 F (sold)
bigbore2
Great, thanx for the replies. I will switch it.
