Fork brace fitting
Started by nurse, May 21, 2013, 04:05:31 PM
nurse
Have recieved mine the other day looks very nice, any tricks, tips/advice on fitting or is it just a case of bolt it up and ride!?! (Loctite on the Allen screws?)
Quote from: nurse on May 21, 2013, 04:05:31 PM
The second part is all that is required
There should have been a small tube of loc-tite included in the package for a drop on each bolt. If not a drop of blue on each bolt is all you need.
Just make sure the forks still travel freely when you torque it down.
nurse
Will check the box again I may have missed it, if not I have plenty, so no panic.
What are your recommend torque settings for the brace?
Quote from: nurse on May 21, 2013, 05:26:20 PM
Tight...
Each one is a little different due to the  sanded portion of the slider of the fork. I use an "L" shaped allen wrench and tighten until comfortable.(which is tight)
I have never applied a torque wrench.
