Oil cooler missing
Started by mrtom, May 12, 2013, 05:16:44 PM
mrtom
Hi,
First time I've used this forum and I'm new to the fj.
It's a 1989
Fj1200
I'm from the UK so I guess its a UK model.
Purchased mine cheap off a guy who I think should be shot. Any way I don't like not understanding why people have done certain things and in this instance the oil cooler is missing. The input and output feed on the sump has a a u shaped pipe feeding straight back into the engine? Is this normal?
Just worried about overheating the thing.
I look forward to your replies
Tom
If in doubt go flat out
Personally I would not ride it without the oil cooler.
The way you describe what the PO has done does not allow for adequate oil cooling. :negative: Heat is the ENEMY of air cooled engines. Randy at RPM has a complete system that gives you everything you need, to have the best oil cooling offered. Here is the link to the oil cooler.
http://www.rpmracingca.com/proddetail.asp?prod=M%2FC%3AFJCoolerKit
mrtom
Thanks for the reply Fred.
I do like the look of the one in the link but It's q little out of my budget at the moment. I may have to source a second hand one off eBay for the time being.
Is this a modification you have heard of in an fj before? I now know from reading on Google on some air cooled bikes people dittch the oil coolers for the cleaner look.
Many thanks
Tom
With the members here that have upgraded their coolers you will likely find a used one here. Just ask.
mrtom
Quote from: mrtom on May 13, 2013, 04:03:42 AM
If one doesn't show up on here would this one fit?
http://pages.ebay.com/link/?nav=item.view&id=221206792250
Tom
It does look like it will fit, I think they are same for all years.
mrtom
Cheers mate.
I've Updated my personal info.
ELIMINATOR
BMW 1150GS
Moto Guzzi California 3
mrtom
Thanks for the help guys. Have ordered one off eBay for now to get me through the Summer and will look at up grading soon. Having said that it I didn't realise it was missing until the other day  :scratch_one-s_head: and I've done nearly 600 miles on it.
