Idle speed too high?
Started by royboy, March 12, 2010, 02:48:25 PM
royboy
Hi, Just bought a 92' 1200FJ and love it to bits, the idle speed is too high and I am trying to locate the adjuster, is it under the tank? or can I get at it through the side casing?
I have a manual on order, until then I have to guess.
Roy
you can get to it by removing the seat and the left hand side cover.
the idle adjustment knob is underneath and in between the middle two carbs.
its kind of a tight fit but can be accessed.
make sure the bike is up to normal operating temp before adjusting.
Kookaloo!
frank
FJ Flyer
What's "too high"?  It should be idling right around 1000-1100 rpm.
The idle adjuster is a toothed-like wheel which points down between the two middle carbs.
If your hand is too big or its hot, use a long flat bladed screwdriver to reach it.
Chris P.
'16 FJR1300ES
'87 FJ1200
'76 DT250
Wear your gear.
royboy
Quote from: racerman_27410 on March 12, 2010, 03:03:15 PM
Kookaloo!
frank
cheers
it was idling at around 1200rpm, Thanks for the info.
Roy
wheels
Quote from: royboy on March 12, 2010, 02:48:25 PM
hey roy boy  have a look at the throatle end  of your cables you can adjust the idle  from there as well it might be turned out just turn it back in
Yamifj1200
Roy you have a 92 and you should be able to adjust the idle by sticking your hand under the carb assembly from the right hand side of the bike unless you have really large hands. In the middle of the carb assembly there is a small hand wheel that you should be able to get to and turn your idle down.
Eric M
royboy
Cheers, that done the trick.
Much appreciated.
Roy
