US Breakers
Started by Dads_FJ, March 19, 2013, 12:30:06 PM
Looking for reputable breakers in the good ol' USofA.  (Non-FJ).  I need a rear axle for my 300cc Suzuki King-Quad.  The tires were frozen in ice and my son thought he could break it loose using low-range.  Well it broke all right - Live-n-learn!  He learned the meaning of Torque:
"Torque, moment or moment of force (see the terminology below), is the tendency of a force to rotate an object about an axis,[1] fulcrum, or pivot. Just as a force is a push or a pull, a torque can be thought of as a twist to an object."
'94 Yamaha WR250
Steve_in_Florida
Sorry to see that.
We don't get much of that `round these parts (The Sunny South).
`90 FJ-1200
`92 FJ-1200
IBA # 54823
Not sure what year/ front back you need, but this guy has a front for a 1999.  There may also be interchangeability between model sizes, you need to look at parts fiche for part #'s
http://www.cycleatvparts.com/suzuki-parts.htm
Quote from: Dan Filetti on March 19, 2013, 02:48:05 PM
Mine has independent rear suspension and I need the back right.  My quad is a '92.  I think the straight axle ebay item you found may be actually for a 250cc.  I appreciate you help!
John
'94 Yamaha WR250
If you come up with an o.e. part number, shoot it to me and i will check cost and availablity.
Randy + RPM
Quote from: racerrad8 on March 19, 2013, 04:03:08 PM
Randy + RPM
Thanks Randy, my son came up with:
AXLE, REAR  64710-39D00
'94 Yamaha WR250
