Cam Chain
Started by jscgdunn, February 15, 2013, 04:53:08 PM
jscgdunn
Hi Everyone,
While  adjusting valve shims on our 86 I noticed the cam chain seems to have more slop than the other bikes as reverse the the motor from clockwise to counterclockwise.
Is there a way to know what the correct tightness is?
As I understand it the auto adjuster should be keeping the correct tension on.
Thanks and Regards,
Jeff
90 FJ 1200 (Son # 2), Stock
dont spin the engine in reverse..... the tensioner system is only designed to operate with the cam chain turning in the proper direction.
