Oil change mistake?
Started by Riolongo, April 23, 2013, 11:35:38 PM
Riolongo
I just changed the oil for the first time on my 92 FJ 1200 and mistakenly put the wrong oil in, need to know if this is a concern or not?
The bike had Maxima Extra4  High Performance 4 cycle 100% ester based synthetic(Triple ester formula) 10w40 oil in it. I  put in Maxima Premium4 High Performance 4 cycle (Advanced trimetallic formula) 10w40 .
Will this be a problem and should I drain and replace with the synthetic oil?
Says its good for "integrated transmissions" - I guess it depends if this also means wet clutches. but then again, the first one doesn't say anything about wet clutches either.  :empathy:
yamaha fj rider
Just checked on line and you will be fine. Designed for motorcycle engines air or water cooled, transmissions and wet clutches. Don't worry go for a ride. Hope this helps.
Kurt
93 FJ1200
FJ 09
YZ250X I still love 2 strokes
Tenere 700
FJR1300ES
keand3
It's tempting to say, oil is oil...  :rofl2:
Kurt beat me to it, you should bee fine :good2:
Ken
Riolongo
Thanks for the replies, I'll run it as it is for now and see how it performs.
