89 FJ1200 TACHOMETER
Started by KBLFJ1200, January 08, 2013, 03:49:42 PM
HOW DO I CHECK TACHOMETER?
HELP
0 (0%)
FJ12100 TACH
1 (100%)
Total Members Voted: 1
KBLFJ1200
Does anyone know about FJ tachometers?  Had an electrical surge, (regulator failed on supposed rebuilt alternator/generator, blew out all bulbs and turn signal flasher/relay and battery. Got it all back together Tach don't work, nothing in service manual.    How do I check tach?  Lot of work R&Ring.  HELP!!!!.
I wish I would have known tach didn't work when I had the whole thing apart, maybe some kind of breaker/fuse in the wiring somewhere or do I have to take dt all apart again and replace the entire tach?
Thanks,
Karl
Contact at KBLFJ1200@AOL.COM
Karl
i wouldnt be surprised if it fried the tach.... i've had a bad ground before and it melted the battery posts clean off the battery.... i imagine a bad regulator could cause similar damage.
KBLFJ1200
Quote from: racerman_27410 on January 08, 2013, 04:33:37 PM
Ok thanks that is what I thought.  I just hate to have take it all apart again, I wonder if anyone out there has a tach?
Karl
Karl
Had that one happen too - but in an airplane!
I should have a good tacho, what would you swap for it :scratch_one-s_head:
