Brake banjo fitting size???
Started by 93fj1200, November 21, 2012, 07:57:45 PM
93fj1200
Would anyone know what is the exact size, pitch, length of the banjo bolts used on the rear brakes of the FJ.  I have installed the GSX-R 5.5 inch rear rim and the Suzuki brake hose ends are thicker and their banjo bolts are a different pitch. My FJ banjo bolt that mounts on the rear master cylinder does not seem long enough.  I can bleed it and drive only a mile or two and it is loose. I looked up the size for the suzuki online and it says it is 10x1.00x24.  I am thinking that the 10 is the diameter of the bolt, 1.00 is the length and 24 is the pitch. I can´t find anything that says what the Yamaha uses.
tmkaos
Measuring my one right here in my hands and it's M10 x 1.25 pitch, from the shoulder of the bolt head to the end of the thread it's 18mm. Bolt head is 14mm AF.
Hope that helps.
James
'92 FJ1200 - '07 to present
'83 VF750S Sabre - '04 - '07
'87 VT250FG - '94 - '98
93fj1200
Quote from: tmkaos on November 21, 2012, 08:03:03 PM
Hope that helps.
James
Thanks for your excellent quick response.  Then I would need to find a M10 x 1.25 x 24??
Greg
tmkaos
Quote from: 93fj1200 on November 21, 2012, 08:26:26 PM
Greg
That sounds about right.
Just be careful of the length measurement. Some people will measure it as an overall, from top of the bolt head to the end, some people will measure it from the shoulder as shown in the picture. I would imagine you will need to have between 10mm to 15mm of thread sticking out the end of the banjo for it to grab properly in the  master cylinder.
Good luck.  :good2:
I don't know what the actual thread pitch is on the FJ or the GSXR. I recently did the GSXR Wheel mod with the GSXR rear caliper. I do know that the FJ Banjo bolts are a course thread and the GSXR Banjo bolts are a fine thread. Maybe I got lucky, I went to a local non oem motorcycle shop and asked for a fine thread banjo bolt. They had one in stock. I took it home and installed it. Works great.
93fj1200
Quote from: aviationfred on November 21, 2012, 08:47:14 PM
I tried that here in Panama and it is almost impossible to jury rig things here because nobody knows what they stock in their stores.  Most of the vendors here are Chinese or Panamenians without any interest in their jobs.  The typical response I got today is NO, we don´t have any and when they say NO, it means NOOOOOOOOO, go away and don´t bother me, even if you bought it there yesterday.  Definitely different cultures than we are used to.  We are problem solvers, here they are not.
